.NET
Active Contributor
murali.pandey
Message 1 of 7 (270 Views)
autoCad application setup
270 Views, 6 Replies
05-06-2012 11:30 PM
Hi
How can I create a setup for autocad  map application. I just want to load the tool (dot net Arx C#) application from user installation directory.
Murali
Valued Mentor
KerryBrown
Message 2 of 7 (261 Views)
Re: autoCad application setup
05-07-2012 01:05 AM in reply to: murali.pandey
Write the code.
Compile.
Either NETLOAD
or configure through the registry to demand load.
Regards
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Moderator
Alexander.Rivilis
Message 3 of 7 (255 Views)
05-07-2012 02:06 AM in reply to: murali.pandey
Valued Mentor
KerryBrown
Message 4 of 7 (231 Views)
05-07-2012 12:43 PM in reply to: Alexander.Rivilis
Alexander, I didn't think the AutoLoader would load from user defined folders ... I'll need to re-read those links.
Regards
Moderator
Alexander.Rivilis
Message 5 of 7 (226 Views)
05-07-2012 12:59 PM in reply to: KerryBrown
Regards
Kerry! I do not understand where these topics AutoLoader? These topic's are about creating setup (MSI). ;-)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Mentor
KerryBrown
Message 6 of 7 (215 Views)
05-07-2012 05:36 PM in reply to: Alexander.Rivilis
I may have misinterpreted the OP's question.
Regards
Valued Mentor
KerryBrown
Message 7 of 7 (197 Views)
05-08-2012 07:23 PM in reply to: KerryBrown
Would be nice if the OP came back to comment :smileyhappy:
