.NET
AutoCad 32 bit won't hit break points
3 REPLIES 3
quigs
7024 Views, 3 Replies
I have aquired a new Win 7 32bit laptop.  Now when I debug in 2011, I can't use edit and continue. 2010, 2012 & 2013 are all fine.  Why would this be.  I installed all 4 from the installer with no changes.
Ta,
Martin.
My name is Martin.. 😄
3 REPLIES 3
quigs
in reply to: quigs
BUMP.
No one else sufferig like me:  New 32 bit Win 7 Pc, new 2011 install, new VS2010 insta;.  Cant hit break points.  No one else? :d
Alfred.NESWADBA
in reply to: quigs
what Framework have you set in your 2011-project? It should be 3.5 (I'm wondering why you get the breakpoints with 2010 as this would also not use Framework 4 like 2012 and 2013).
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
quigs
in reply to: Alfred.NESWADBA
Ahaha,
found it, the config file had the correct .net info but it was all commented out.
Thanks group :D.
”Boost
