.NET
Distinguished Mentor
BlackBox_
Message 1 of 7 (813 Views)
AutoCAD 2015 .NET Wizard
813 Views, 6 Replies
07-23-2014 08:36 AM
I keep forgetting to post things like this here, instead of at other forums; apologies for the duplication.
After reading Kean state that we need to use Visual Studio 2012 or 2013 for AutoCAD 2015 products:
"Do bear in mind that to target .NET 4.5 – which is a requirement to use the API enhancements in AutoCAD 2015 – you will need to use Visual Studio 2012 or 2013: VS2010 cannot target .NET 4.5. (ObjectARX developers will have to use the toolset from VS2012 to compile their C++ modules, as that’s the compiler being used to build AutoCAD.) I’m personally now using VS2013 as a primary IDE, but make use of the VS2012 toolset when building ObjectARX modules."
... I installed Visual Studio 2013 Ultimate from MSDN. That said, I noticed something curious with the 2015 wizard - I should note that all of my solutions open, debug, and compile just fine, but there seems to be something wonky with the 2015 .NET Wizard (MSI dated 11/19/2013) for new projects.
Is it just me, or does anyone else have an issue with the new wizard, where the 2015 C# project template is only visible when .NET Framework 4.0 is specified in the New Project dialog, whereas the 2015 VB project template is visible when .NET Framework 4.5 is specified?
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
AutoCAD® 2014, and Civil 3D® 2014 Certified Professional ~ Autodesk® Authorized Developer
I do not see any other reason why this would happen unless the project template is incorrect for some reason.
The information that controls when the template has to appear inside Visual Studio is embedded in the Visual Studio Project template file.
Can you please check if there is something wrong with that file ?
You will find the template install path under the following key in Registry :
HKCU\Software\Microsoft\VisualStudio\12.0 -> UserProjectTemplatesLocation
In my system, this points to C:\Users\<My User name>\Documents\Visual Studio 2013\Templates\ProjectTemplates
Under this folder, you will find the "Visual Basic\Autodesk" and "Visual C#\Autodesk" sub folders with the project templates.
Please unzip the file, and open "MyTemplate.vstemplate" file in an editor. This file should have the framework specified as
<RequiredFrameworkVersion>4.5</RequiredFrameworkVersion>
<MaxFrameworkVersion>4.5</MaxFrameworkVersion>
This will ensure that the project template only appears if it is 4.5
Since you mention that it works ok for the C# template, maybe comparing the template file under "visualC#\Autodesk" will be of some help.
Balaji
BlackBox_
Message 2 of 7 (790 Views)
Re: AutoCAD 2015 .NET Wizard
07-23-2014 11:33 AM in reply to: BlackBox_
I know you guys are short staffed at the moment, however, could someone from Autodesk, ADN, etc. confirm this?
Cheers
ADN Support Specialist
Balaji_Ram
Message 3 of 7 (761 Views)
07-24-2014 02:21 AM in reply to: BlackBox_
I do not see this behavior in my system.
The Visual Basic and C# templates appear only when the .Net framework is 4.5 and not in 4.0.
I am not sure if this affects the results - I installed AutoCAD 2015 .Net wizard in a system that already had VS 2012 and VS 2013 Professional installed in it.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji_Ram
Message 4 of 7 (755 Views)
07-24-2014 03:08 AM in reply to: Balaji_Ram
Just tried on another system that only had VS 2012 and the .Net wizard for 2015 installed. After I installed VS 2013 in it, the templates did not appear at all. I think that is expected since the wizard did not place the templates for VS 2013 to find.
So had to uninstall the .Net wizard and reinstall it for the templates to appear in VS 2013.
Sorry, not sure what else could be causing this problem in your system. Does a reinstall of the .Net wizard change the behavior ?
Balaji
Balaji
BlackBox_
Message 5 of 7 (748 Views)
07-24-2014 05:37 AM in reply to: Balaji_Ram
Hi Balaji,
Yes, I have tried uninstalling, and re-installing the 2015 wizard.
Interestingly, prior to uninstall, I had extracted a copy of the C# template. After uninstall, the extracted template did show up for 4.5 Framework. So, I re-installed the wizard, and then both the .ZIP re-installed and the extracted copy were no longer visible under 4.5 Framework, and only visible under 4.0 Framework.
Balaji_Ram
Message 6 of 7 (693 Views)
07-30-2014 05:01 AM in reply to: BlackBox_
Balaji
Balaji
BlackBox_
Message 7 of 7 (676 Views)
07-30-2014 08:26 AM in reply to: Balaji_Ram
Balaji
That's the issue, Balaji; the My Template.vstemplate file in ..\Visual C#\Autodesk\ directory.
Among several differences, both the RequiredFrameworkVersion, and MaxFrameworkVersion XmlNodes are missing from AutoCAD 2015 CSharp plug-in.zip, dated 2013-11-19... Here's a quick side-by-side comparison:
[Edit] - The forums scale the image, and it is not selectable to view full-size, so here's a link to do just that.
Adding said XmlNodes, and values does correct the issue.
Cheers
