.NET
osayed3202
Message 1 of 3 (216 Views)
Autocad 2014 processor error message
216 Views, 2 Replies
01-15-2014 01:57 AM
dear guys,
please i was working in the project and the assebliy was loading on Autocad 2014 without any problems but i tried to open it today I found this message below and the processor choosen as image attached is 'Any' and the attched text file shows the message when i am loading the assebly.
so i am struggling whts going on
"Warning 2 There was a mismatch between the processor architecture of the project being built "MSIL" and the processor architecture of the reference "accoremgd", "AMD64". This mismatch may cause runtime failures. Please consider changing the targeted processor architecture of your project through the Configuration Manager so as to align the processor architectures between your project and references, or take a dependency on references with a processor architecture that matches the targeted processor architecture of your project. ZFP-XrefBind-2014"
and also for the other references.
Best Regards
O.Sayed
CAD developer
HI ,
you can take a look in below link where same Problem has been discussed.
http://forums.autodesk.com/t5/NET/Mismatch-Processor-AMD64-vs-MSIL/td-p/3796563
mzakiralam
Message 2 of 3 (197 Views)
Re: Autocad 2014 processor error message
01-15-2014 04:43 AM in reply to: osayed3202
HI ,
osayed3202
Message 3 of 3 (142 Views)
01-20-2014 07:40 AM in reply to: mzakiralam
thank you very much I changed the processor to be 64bit
Best Regards
O.Sayed
CAD developer
