.NET
Valued Mentor
kevin.barnett
Message 1 of 2 (1,259 Views)
AutoCAD 2014 interop application ID
1259 Views, 1 Replies
04-02-2013 04:10 AM
What is the string to use with Marshal.GetActiveObject to get the active AutoCAD 2014 application?
This works with 2013: AutoCAD.Application.19
For 2014, I tried: AutoCAD.Application.20  ... but this appears to be incorrect.
AutoCAD.Application works, but that would get access to almost any running AutoCAD version, I specifically need to access version 2014.
Thx.
Kevin.
Valued Mentor
kevin.barnett
Message 2 of 2 (1,250 Views)
Re: AutoCAD 2014 interop application ID
04-02-2013 05:07 AM in reply to: kevin.barnett
oops... I found it ... but maybe someone will still need this..
the ACADVER system variable displays the version, 2014 is 19.1
answer:  "AutoCAD.Application.19.1"
