.NET
AutoCAD 2014 interop application ID
1 REPLY 1
kbarnettza
2737 Views, 1 Reply
What is the string to use with Marshal.GetActiveObject to get the active AutoCAD 2014 application?
This works with 2013: AutoCAD.Application.19
For 2014, I tried: AutoCAD.Application.20  ... but this appears to be incorrect.
AutoCAD.Application works, but that would get access to almost any running AutoCAD version, I specifically need to access version 2014.
Thx.
Kevin.
1 REPLY 1
kbarnettza
in reply to: kbarnettza
oops... I found it ... but maybe someone will still need this..
the ACADVER system variable displays the version, 2014 is 19.1
answer:  "AutoCAD.Application.19.1"
”Boost
