What is the string to use with Marshal.GetActiveObject to get the active AutoCAD 2014 application?
This works with 2013: AutoCAD.Application.19
For 2014, I tried: AutoCAD.Application.20 ... but this appears to be incorrect.
AutoCAD.Application works, but that would get access to almost any running AutoCAD version, I specifically need to access version 2014.
Thx.
Kevin.
Solved by kbarnettza. Go to Solution.
oops... I found it ... but maybe someone will still need this..
the ACADVER system variable displays the version, 2014 is 19.1
answer: "AutoCAD.Application.19.1"
