.NET
.NET
Active Member
hongmei
Message 11 of 13 (244 Views)
Re: Autocad 2013, plane cut solid3d, to get region, access region, autocad crash
04-04-2013 10:33 AM in reply to: Alexander.Rivilis
I am ADN member, they fixed my account today, I already post the question to them.
so, you found the problem, Thank you very much, sorry for confusing you by my bad code
how to get around this, not causing ACAD2013 crash, I don't mind ignore cutting some objects.
I will call obj.Dispose(),
Active Member
hongmei
Message 12 of 13 (209 Views)
05-03-2013 12:46 PM in reply to: hongmei
hello,
I wonder if you can help.
nobody can reproduce this error from Autodesk, you are the only one.
strange thing for me:
if I set breakpt in reg=sol.GetSection(pln) ,
run step by step, it won't crash, just throw exception here, and catch in here.
if no breakpt set, it will crash,
if set breakpt if (reg==null || reg.IsNull) , I can see the reg properties are not valid
not all the ACAD2013 behave the same.
I have ACAD2013 on my virtual machine works fine. I tried to add all my other addins, still works
ACAD2013 on my real machine crashes, I removed all my other addins, still crashes
I need to find the reason, or find a solution to get around this, I can ignore cutting some objects
appreciate any help
Active Member
hongmei
Message 13 of 13 (206 Views)
05-03-2013 01:05 PM in reply to: Alexander.Rivilis
hello, Alex
appreciate any help
Announcements
Need installation help?
