.NET
.NET
Active Member
hongmei
Message 1 of 13 (844 Views)
Autocad 2013, plane cut solid3d, to get region, access region, autocad crash
844 Views, 12 Replies
04-03-2013 11:56 AM
Moderator
Alexander.Rivilis
Message 2 of 13 (838 Views)
Re: Autocad 2013, plane cut solid3d, to get region, access region, autocad crash
04-03-2013 12:05 PM in reply to: hongmei
Maybe you post yours code?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Member
hongmei
Message 3 of 13 (833 Views)
04-03-2013 12:21 PM in reply to: Alexander.Rivilis
using
System;
using
System.Collections.Generic;
using
System.Linq;
using
System.Text;
using
Autodesk.AutoCAD.Runtime;
using
Autodesk.AutoCAD.ApplicationServices;
using
Autodesk.AutoCAD.DatabaseServices;
using
Autodesk.AutoCAD.EditorInput;
using
Autodesk.AutoCAD.Geometry;
using
acadAPP = Autodesk.AutoCAD.ApplicationServices.Application;
namespace
Solid3dCut2013
publicclassClass1
CommandMethod("ACut_Solid3d")]
publicstaticvoidACut_Solid3d()
Document doc=acadAPP.DocumentManager .MdiActiveDocument ;
try
ObjectIdsolId;
Planepln;
ObjectIdCollectionobjIds;
pickSolid3d (doc,
out solId ,out pln ,outobjIds);
if (solId ==ObjectId .Null || pln ==null ) return;
using (DocumentLockdlock=doc.LockDocument ())
using (Transactiontrans=doc.TransactionManager .StartTransaction ())
foreach (ObjectId objId inobjIds)
CutSolid(doc, trans, objId , pln);
trans .Commit ();
catch (System.Exceptionex)
doc.Editor .WriteMessage (ex.Message +
"\n");
publicstaticvoid pickSolid3d(Document doc, outObjectId solId, outPlane pln,outObjectIdCollectionobjIds)
solId =
ObjectId.Null;
pln =
null;
objIds =
null;
PromptSelectionResultpsr= doc.Editor.SelectAll();
objIds =
newObjectIdCollection( psr.Value.GetObjectIds());
PromptEntityOptions peo = newPromptEntityOptions("pick solid3d: ");
peo.SetRejectMessage(
"solid3d only \n");
peo.AddAllowedClass(
typeof(Solid3d), true);
PromptEntityResultper = doc.Editor.GetEntity(peo);
while (true)
if (per.Status == PromptStatus.Cancel) return;
if (per.Status != PromptStatus.OK) continue;
solId =per.ObjectId ;
Point3dpt=per.PickedPoint ;
Solid3d sol=(Solid3d ) trans .GetObject (solId ,OpenMode.ForRead );
doublez= (sol.GeometricExtents .MinPoint.Z +sol .GeometricExtents .MaxPoint .Z ) /2;
pt=
newPoint3d(pt.X,pt.Y ,z);
pln=
newPlane (pt,newVector3d(1,1,1).GetNormal () );
trans .Commit ();
return;
staticpublicvoid CutSolid(Document doc, Transaction tr, ObjectId solId, Planepln)
Entity ent = (Entity)(tr.GetObject(solId, OpenMode.ForRead));
if (ent == null)
return;
if (ent.GetType() != typeof(Solid3d))
return;
Solid3d sol = (Solid3d)ent;
sol.Highlight();
doc.Editor.WriteMessage(
"objId: "+solId .ToString ()+"\n");
PromptStringOptions pso = newPromptStringOptions("continu...");
doc.Editor.GetString(pso);
sol.Unhighlight();
Region reg = null;
try
reg = sol.GetSection(pln);
catch (Autodesk.AutoCAD.Runtime.Exceptionex)
doc.Editor.WriteMessage(ex.Message +
"\n");
return;
catch (System.Exceptione)
//MessageBox.Show(e.Message);
doc.Editor .WriteMessage (e.Message +
"\n");
return;
try
if (reg==null || reg.IsNull) //add region to DB, otherwise 2013 crash return;
catch (System.AccessViolationExceptionex)
"\n"); // MessageBox.Show(ex.Message);return;
catch (System.Exceptionex2)
doc.Editor.WriteMessage(ex2.Message +
"\n"); //MessageBox.Show(ex2.Message);
DBObjectCollection entCol = newDBObjectCollection();
reg.Explode(entCol);
////add region to DB
BlockTable bt = (BlockTable)(tr.GetObject(doc.Database.BlockTableId, OpenMode.ForWrite));
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
btr.AppendEntity(reg);
tr.AddNewlyCreatedDBObject(reg,
true);
reg.Erase();
if (entCol != null&& entCol.Count != 0)
foreach (DBObject obj inentCol)
if (!(obj isEntity)) continue;
Entity ent1 = (Entity)obj;
ent1.ColorIndex = 6;
//pink
btr.AppendEntity(ent1);
tr.AddNewlyCreatedDBObject(obj,
true);
For some solid3d (not all),  can pass region=solid.getsection();
but when run to the yellow line, all region's properties can't access, can't catch, just cause autocad 2013 crash, ACAD2011 is ok, only ACAD2013
Thank you very much
Moderator
Alexander.Rivilis
Message 4 of 13 (816 Views)
04-03-2013 01:47 PM in reply to: hongmei
1. First of all your code is not readable. Many of keywords are concatenated and if you try copy code from forum to VS and compile it then you get errors. In order to post code please use Insert Code button:
2. I did not see any yellow line although I'm not color blind.
Active Member
hongmei
Message 5 of 13 (811 Views)
04-03-2013 02:04 PM in reply to: Alexander.Rivilis
pink , sorry, I colored it yellow, then I realized yellow is not bright enough, so I changed it to pink, when I wrote the message, I still think the yellow color
Moderator
Alexander.Rivilis
Message 6 of 13 (806 Views)
04-03-2013 02:15 PM in reply to: hongmei
Sorry but in any case, I can not read this code ... Maybe someone else ...
Active Member
hongmei
Message 7 of 13 (776 Views)
04-04-2013 05:42 AM in reply to: hongmei
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using acadAPP = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Solid3dCut2013
    public class Class1
        [CommandMethod("ACut_Solid3d")]
        public static void ACut_Solid3d()
            Document doc=acadAPP .DocumentManager .MdiActiveDocument ;
            try
                ObjectId solId;
                Plane pln;
                ObjectIdCollection objIds;
                pickSolid3d (doc,out solId ,out pln ,out   objIds);
                if (solId ==ObjectId .Null || pln ==null )  return ;
                using (DocumentLock dlock=doc.LockDocument ())
                    using (Transaction trans=doc.TransactionManager .StartTransaction ())
                        foreach (ObjectId objId in objIds)
                        trans .Commit ();
            catch (System.Exception ex)
                doc.Editor .WriteMessage (ex.Message +"\n");
        public static void pickSolid3d(Document doc, out ObjectId solId, out Plane pln,out ObjectIdCollection objIds)
            solId = ObjectId.Null;
            pln = null;
            objIds = null;
            PromptSelectionResult psr= doc.Editor.SelectAll();
            objIds =new ObjectIdCollection ( psr.Value.GetObjectIds());
            PromptEntityOptions peo = new PromptEntityOptions("pick solid3d: ");
            peo.SetRejectMessage("solid3d only \n");
            peo.AddAllowedClass(typeof(Solid3d), true);
            PromptEntityResult per = doc.Editor.GetEntity(peo);
            while (true)
                if (per.Status == PromptStatus.Cancel) return ;
                Point3d pt=per.PickedPoint ;
                        Solid3d sol=(Solid3d ) trans .GetObject (solId ,OpenMode .ForRead );
                        double z= (sol.GeometricExtents .MinPoint.Z +sol .GeometricExtents .MaxPoint .Z ) /2;
                        pt=new Point3d (pt.X,pt.Y ,z);
                        pln=new Plane (pt,new Vector3d (1,1,1).GetNormal ()  );
                        trans .Commit ();
                return ;
        static public void CutSolid(Document doc, Transaction tr, ObjectId solId, Plane pln)
            if (ent == null)
                return;
                return;
            sol.Highlight();
            doc.Editor.WriteMessage("objId: "+solId .ToString ()+"\n");
            PromptStringOptions pso = new PromptStringOptions("continu...");
            sol.Unhighlight();
            Region reg = null;
            try
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                doc.Editor.WriteMessage(ex.Message + "\n");
                return;
            catch (System.Exception e)
                doc.Editor .WriteMessage (e.Message +"\n");
                return;
            try
                    return;
            catch (System.AccessViolationException ex)
                doc.Editor.WriteMessage(ex.Message + "\n"); // MessageBox.Show(ex.Message);
                return;
            catch (System.Exception ex2)
                doc.Editor.WriteMessage(ex2.Message + "\n"); //MessageBox.Show(ex2.Message);
            DBObjectCollection entCol = new DBObjectCollection();
            tr.AddNewlyCreatedDBObject(reg, true);
            reg.Erase();
            if (entCol != null && entCol.Count != 0)
                foreach (DBObject obj in entCol)
                    if (!(obj is Entity)) continue;
                    ent1.ColorIndex = 6;  //pink
                    tr.AddNewlyCreatedDBObject(obj, true);
Moderator
Alexander.Rivilis
Message 8 of 13 (770 Views)
04-04-2013 06:26 AM in reply to: hongmei
I have to your code so many questions that do not even know where to start.
1. Function pickSolid3d:
a) if user not select Solid3d (missed) then infinite loop and AutoCAD hang because you do not change per inside the while loop.
b) you really need such cutting plane:
            pln = new Plane(pt, new Vector3d(1, 1, 1).GetNormal());
or you need horizontal cutting plane?
2. Function CutSolid:
a) why you open BlockTabe forwrite?
b) what entities you can try add to BlockTableRecord - Region or exploded Region?
c) why you add Region to BlockTableRecord and once it is erased?
This is just what I saw quickly viewing your code.
Active Member
hongmei
Message 9 of 13 (765 Views)
04-04-2013 08:03 AM in reply to: Alexander.Rivilis
Thank you for your patience,
I was about to ask ADN support this question, but for some reason, I can't access ADN my account
This piece of code is I made up temporary to raise the error, it is full of mistakes if you set a high standard.
my purpose is to make the problem appear, on this line, reg.isNull || reg==null , cause autocad2013 crash, which I couldn't catch
your question
1. picksolid3d
  a.my purpose is to pick a solid, I have a drawing which has all solid3d
  b. my cut plane can be any, I just make up this one to make the error appear, horizontal plane can't make the error
2. cutsolid
  a.blockTable open for write, not necessary
  b.entities add to model space are entites after explode the region,
  c. region is created tempary, if I don't do anything , it will cause memory leak, if I delete it directly will cause error 'not in database'. so I need to add it to model splace, add to transaction, then I can delete it safely and no memery leak
Moderator
Alexander.Rivilis
Message 10 of 13 (762 Views)
04-04-2013 09:26 AM in reply to: hongmei
hongmei wrote:
...I was about to ask ADN support this question, but for some reason, I can't access ADN my account...
Are you ADN member? If yes why you can not access DevHelp? Maybe you have to e-mail ADN administrator? If you have not his e-mail then PM me.
hongmei wrote:
...my purpose is to make the problem appear, on this line, reg.isNull || reg==null , cause autocad2013 crash, which I couldn't catch
I can reproduce this behavior. Maybe it's a bug, maybe no...  If cutting plane has not intersection with Solid3d then calling reg.isNull produce exception.
hongmei wrote:
...  c. region is created tempary, if I don't do anything , it will cause memory leak, if I delete it directly will cause error 'not in database'. so I need to add it to model splace, add to transaction, then I can delete it safely and no memery leak
As usually enough to call reg.Dispose() in order to free its memory.
