.NET
Valued Mentor
kevin.barnett
Message 1 of 5 (3,130 Views)
autocad 2013 CommandMethod assembly reference
3130 Views, 4 Replies
04-12-2012 03:20 AM
Microsoft Visual C# 2010 Express
Trying to create first dll in 2013,
referenced acdbmgd and acmgd (as usual, as in previous versions)
then included:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
but ...
Error in IDE (Visual C#) when entering: [CommandMethod("TEST")]
Error: CommandMethod could not be found .. are you missing a using directive or an assembly reference
What did I miss?
Thx.
Kevin.
for AutoCAD 2013 you have to reference a third dll by default: AcCoreMgd.dll (to be found in the installation directory of AutoCAD).
HTH, - alfred -
Alfred.NESWADBA
Message 2 of 5 (3,129 Views)
Re: autocad 2013 CommandMethod assembly reference
04-12-2012 03:30 AM in reply to: kevin.barnett
HTH, - alfred -
Alfred NESWADBA
Valued Mentor
kevin.barnett
Message 3 of 5 (3,126 Views)
04-12-2012 03:35 AM in reply to: Alfred.NESWADBA
Thank You ...
Valued Mentor
KerryBrown
Message 4 of 5 (3,117 Views)
04-12-2012 04:10 AM in reply to: kevin.barnett
For Reference :
http://through-the-interface.typepad.com/through_the_interface/2012/03/migrating-net-applications-to...
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
New Member
ncolangelo
Message 5 of 5 (2,802 Views)
08-10-2012 12:20 PM in reply to: kevin.barnett
Excellent - exactly what I needed!
