.NET
AutoCAD 2013 & Visual Studio version
5 REPLIES 5
Luigi71
1408 Views, 5 Replies
Hi to all,
as per the title, to develop VB.NET applications for AutoCAD 2013 on Windows7 x64, which version of Visual Studio and framework are needed?
5 REPLIES 5
mzakiralam
in reply to: Luigi71
you can use Visual Studio 2010 and Framework must but 4.0
mzakiralam
in reply to: mzakiralam
*Frame work must be 4.0 or above in this case
Luigi71
Thankyou mzakiralam for the information.
In fact I had already used VisualStudio 2010 for AutoCAD 2013, but I was not quite sure of the combination.
Alexander.Rivilis
I would recommend to install Service Pack 1 for VS 2010
Facebook | Twitter | LinkedIn
Expert Elite Member
Luigi71
in reply to: Alexander.Rivilis
Thankyou Alexander, I'll keep in mind.
This seems a good place to download VS2010 SP1
”Boost
