.NET
New Member
0 Kudos
Post 1 of 4
AutoCad 2012
220 Views, 3 Replies
04-23-2012 01:29 AM
First, sorry for my bad english...
I try tocreate a vb.net exe which update tags of block of my drawing opened on Autocad.
I have added Reference to AutoCad 2012 Type Library and ObjectDBX Common 18.0 Type Library
When i do that :
Dim acadapp As Autodesk.AutoCAD.Interop.AcadApplication
Dim acaddoc As Autodesk.AutoCAD.Interop.AcadDocument
I have an error on line 2 which says that I have any versions of Autodesk.AutoCAD.Interop.Common (18.0.0.0 and 18.2.0.0).
I don't know how can I get ObjectDBX in 18.2.0.0 version.
Thanks a lot
1,219 Kudos
Post 2 of 4
Re: AutoCad 2012
04-23-2012 01:51 AM in reply to: cmoutier
what version of Visual Studio do you use?
To the message you get .... can you upload a screenshot from what VS shows to you exactly, I don't understand that message (other words, I'm surprised about what you are getting as error).
- alfred -
Alfred NESWADBA
New Member
0 Kudos
Post 3 of 4
Re: AutoCad 2012
04-23-2012 01:55 AM in reply to: Alfred.NESWADBA
I use Visual Studio 2010.
I attach screenshots but they are in French...
Thanks a lot
1,219 Kudos
Post 4 of 4
Re: AutoCad 2012
04-23-2012 02:11 AM in reply to: cmoutier
sorry, I don't know the French language ;(
I just see on your screenshot that your references has a switch set to on (in your screenshot the property window on the lower-right corner shows:
Incorporer les.... ==> that is set to yes
If that means something like "embed interop types" ... then you have to set that to false!
If that does not help, can you show a fewe lines in your code that are initiating the error? E.g. lines 16, 21, 22
And to make sure: your Microstation library is placed on network? That may be problematic for Visual Studio because you it sees network-drives as "unsafe/unsecure".
- alfred -
Alfred NESWADBA
