In AutoCAD 2012, I wanted to get the information about a linetype. But it seems that no properties give me that info.
I think it was suppose to be in the "Comments" property. But I have the same info as in the "AsciiDescription" property.
Someone has the same problem or have a workaround?
Thanks!
Solved by Alexander.Rivilis. Go to Solution.
@Anonymous wrote:
...I think it was suppose to be in the "Comments" property. But I have the same info as in the "AsciiDescription" property...
From ObjectARX SDK Docs:
LinetypeTableRecord.AsciiDescription Property
This function is obsolete and will be eliminated in a future release of ObjectARX. Please use Comments instead.
What kind of linetype info you want to get?
Facebook | Twitter | LinkedIn
"FENCELINE1" - Name property
"Fenceline circle ----0-----0----0-----0----0-----0--" - Comments property
"A,6.35,-2.54,[CIRC1,ltypeshp.shx,x=-2.54,s=2.54],-2.54,25.4" - you have to get from other properties/methods of LinetypeTableRecord class
Oh yes some properties and methods give me some infos, I will need to sort that out!
