.NET
Autocad 2012 - Get objects inside layer
10 REPLIES 10
Message 1 of 11
Seegee
3013 Views, 10 Replies
Hey guys, quick question.
I am using Autocad 2012 with the API provided. I am developing in c#.
What I am trying to do is select a certain layer, and "detect" all rectangles / squares in that layer. Ultimateley, I would like to be able to draw inside of all of those rectangles that I have "detected" (using their coordinates).
So far, I am using the LayerTable class along with GetObjects to associate layers with objects, like so:
            String layerNames = "";
            foreach (ObjectId layer in layers)
                LayerTableRecord layerTableRec;
                layerTableRec = acTrans.GetObject(layer, OpenMode.ForRead) as LayerTableRecord;
                layerNames += layerTableRec.Name+"\n";
LayerTable layers; layers = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead) as LayerTable;I can't seem to figure out where to go from here though. How to select just one layer, and then detect shapes inside of it. Can someone point me in the correct direction, in terms of what classes / methods to look into?
Thanks!
Tags (3)
10 REPLIES 10
Message 2 of 11
Keith.Brown
in reply to: Seegee
You could just use a selection filter.  The code below is a direct copy paste from the api help file.  It will select all blue circles on layer 0.
http://docs.autodesk.com/ACD/2014/ENU/index.html?url=files/GUID-BE8B5EE4-9B5A-4D1F-B2D8-7DC013BFC6C0...
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("FilterBlueCircleOnLayer0")]
public static void FilterBlueCircleOnLayer0()
  // Get the current document editor
  Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
  // Create a TypedValue array to define the filter criteria
  TypedValue[] acTypValAr = new TypedValue[3];
  acTypValAr.SetValue(new TypedValue((int)DxfCode.Color, 5), 0);
  acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "CIRCLE"), 1);
  acTypValAr.SetValue(new TypedValue((int)DxfCode.LayerName, "0"), 2);
  // Assign the filter criteria to a SelectionFilter object
  SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
  // Request for objects to be selected in the drawing area
  PromptSelectionResult acSSPrompt;
  acSSPrompt = acDocEd.GetSelection(acSelFtr);
  // If the prompt status is OK, objects were selected
  if (acSSPrompt.Status == PromptStatus.OK)
      SelectionSet acSSet = acSSPrompt.Value;
      Application.ShowAlertDialog("Number of objects selected: " +
                                  acSSet.Count.ToString());
  else
      Application.ShowAlertDialog("Number of objects selected: 0");
Message 3 of 11
Seegee
in reply to: Keith.Brown
Ahh ok. That would select them in Autocad though.
How would I go about getting dimensions / coordinates of each individual object?
Message 4 of 11
Keith.Brown
in reply to: Seegee
Ok...  I threw this example together real fast but i did check it and it worked.  It gets all objects in model space and checks to see if it is a polyline.  It will then open the polyline for read and check to see if it is on the correct layer.  It will then check to see if the polyline is rectangular by verifying it has 4 vertices and if all 4 vertices are perpindicular to each other.  There might be a better/faster way to do it but this is what I came up with.
[CommandMethod("GetAllRectangles")]
public static void GetCircles()
    Document document = Application.DocumentManager.MdiActiveDocument;
    Database database = document.Database;
    Editor editor = document.Editor;
    RXClass rxClassPoly = RXClass.GetClass(typeof (Polyline));
    var count = 0;
    using (Transaction transaction = document.TransactionManager.StartOpenCloseTransaction())
        var blockTable = transaction.GetObject(database.BlockTableId, OpenMode.ForWrite, false) as BlockTable;
	var blocktableRecord = transaction.GetObject(blockTable[BlockTableRecord.ModelSpace], OpenMode.ForRead, false) as BlockTableRecord;
	foreach (ObjectId objectId in blocktableRecord)
	    if (objectId.ObjectClass == rxClassPoly)
	        var poly = transaction.GetObject(objectId, OpenMode.ForRead) as Polyline;
		if (poly.Layer == "0" && poly != null)
		    if (poly.NumberOfVertices == 4)
		        var line0 = poly.GetLineSegmentAt(0);
		        var line1 = poly.GetLineSegmentAt(1);
		        var line2 = poly.GetLineSegmentAt(2);
		        var line3 = poly.GetLineSegmentAt(3);
		        if (line0.IsPerpendicularTo(line1) && line1.IsPerpendicularTo(line2) &&
                            line2.IsPerpendicularTo(line3) && line3.IsPerpendicularTo(line0))
		            count = count + 1;
			    // Put all your rectangle processing code here.
        transaction.Commit();
    editor.WriteMessage(string.Format("\r\nFound {0} rectangles!", count));
Message 5 of 11
Seegee
Hi, sorry for the late reply!
I just tested out that code, and it doesn't seem to be working. I draw a rectangle with a polyline, and then I run GetAllRectangles, but it just outputs Found 0 rectangles every time.
Message 6 of 11
JONTHEPOPE
in reply to: Seegee
since my programming is limited I would use the qselect method.
are better right click object and find select similar
Message 7 of 11
Seegee
It seems that poly.NumberOfVertices is equal to 5 for some reason, when I draw a rectangle.
Message 8 of 11
JONTHEPOPE
in reply to: Seegee
reset cad.pngSounds like a variable problem
if you want reset autocad in you window button
Message 9 of 11
Keith.Brown
in reply to: Seegee
Are you drawing a rectangle or a polyline with 4 sides?  If you are drawing a polyline with 4 sides make sure that you close the polyline instead of trying to mate the last line with the first line.
I ran this code many times and it worked for me everytime when i created a rectangle using the RECTANG command.
Message 10 of 11
Seegee
Got it working, I was clicking with last line. Thanks!
Message 11 of 11
Keith.Brown
in reply to: Seegee
Don't forget to make the post that was the solution for you so others can find the answer quickly.
”Boost
