.NET
Autocad 2012 and 2013
4 REPLIES 4
ditran7577
460 Views, 4 Replies
Hi All,
Autocad 2012 and 2013 both run under NET FRAMEWORK 4.0. So, is there a way to build *.dll file for them?
4 REPLIES 4
mzakiralam
in reply to: ditran7577
Your question is not so clear. What are you looking for actually?
arcticad
if you want to make an application that loads into AutoCAD is has to be a .dll file.
You would create a class library project and load it.
The fact that is uses .net 4.0 doesn't matter. .
(defun botsbuildbots() (botsbuildbots))
ditran7577
I want to build a *.dll file under Net framework 4.0 foundation. And It can work OK both Autocad 2012 and 2013.
Is there any way?
Maybe you are talking about making one compilation for both versions?
If you are, I think it is not possible because of the "extra" reference needed in 2013 version "accoremgd.dll", you will need to make two proyects instead only one.
Luis Alberto Manero, Geograma.com
”Boost
