.NET
Member
0 Kudos
Post 1 of 4
AutoCad 2011 Not Open
299 Views, 3 Replies
04-05-2012 06:44 PM
Hi.
I'm CAD Addin developer.
Um ...
AutoCAD 2010 OPEN success.
AutoCAD 2012 OPEN success.
But .... AutoCAD 2011 OPEN failure.
AutoCAD 2010, 2011, 2012 all same source.
Why Not OPEN AutoCAD 2011 ... TT.
DWGCHECK applied ...
Dev Tool: Visual Studio 2008
CAD: AutoCAD Mechanical 2011
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim acadApp As AcadApplication
        Try
            If acadApp Is Nothing Then
                acadApp = GetObject(, "AutoCAD.Application")
            End If
            acadApp.Visible = Visible
        Catch ex As Exception
            Try
                acadApp = CreateObject("AutoCAD.Application.18.1")
                'Shell("C:\Program Files\Autodesk\ACADM 2011\acad.exe")
            Catch ex1 As Exception
                MsgBox(ex1.Message)
            End Try
        End Try
    End Sub
Valued Contributor
3 Kudos
Post 2 of 4
Re: AutoCad 2011 Not Open
04-05-2012 06:48 PM in reply to: ywseo
Did you try debugging it?
In which line do you get the error?
Valued Mentor
22 Kudos
Post 3 of 4
04-05-2012 07:32 PM in reply to: ywseo
are you accessing
18.0
18.1
18.2
Regards
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
ADN Support Specialist
100 Kudos
Post 4 of 4
04-06-2012 04:54 AM in reply to: ywseo
Using the version independent program id as “AutoCAD.Application” should invoke the last run version of AutoCAD.
So you may want to check which version of AutoCAD was invoked just before you run this code.
If not you can mention the prog id of a AutoCAD version that you specifically want to launch.
Ex : “AutoCAD.Application.18.1” for AutoCAD 2011.
Using the registry editor open the following key and note the CLSID :
“HKEY_CLASSES_ROOT\AutoCAD.Application\CLSID”
For ex : If the CLSID is “6D7AE628-FF41-4CD3-91DD-34825BB1A251”
Look for  “HKEY_CLASSES_ROOT\CLSID\{6D7AE628-FF41-4CD3-91DD-34825BB1A251}\LocalServer32”
The path to the executable that will be launched when “AutoCAD.Application” is specified can be verified here.
Be careful while working with the registry editor.
Balaji
Developer Technical Services
Autodesk Developer Network
