.NET
autocad 2010 crashes after transiction
12 REPLIES 12
Message 1 of 13
573 Views, 12 Replies
I've this problem
I'm triyng to change the Z value of lines in my draweing with this code
        <Autodesk.AutoCAD.Runtime.CommandMethod("SETZETA")> _
        Public Shared Sub AzzeraAsseZETA()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim dbObj As DBObject
            Dim zeta As Single = 0
            ed.CurrentUserCoordinateSystem = Matrix3d.Identity
            ed.Regen()
            Using docLock As DocumentLock = doc.LockDocument()
                Using tr As Transaction = db.TransactionManager.StartTransaction
                   Dim filterforLine() As TypedValue = {New TypedValue(0, "LINE")}
                   Dim sf As SelectionFilter = New SelectionFilter(filterforLine)
                   Dim pSelRes As PromptSelectionResult = ed.SelectAll(sf)
                    Dim pSelRes As PromptSelectionResult = ed.SelectAll()
                    Try
                        If (pSelRes.Status <> PromptStatus.OK) Then
                            tr.Abort()
                            Exit Try
                        End If
                        Dim objIdArray() As ObjectId = pSelRes.Value.GetObjectIds()
                        For Each objId As ObjectId In objIdArray
                              dbObj = tr.GetObject(objId, OpenMode.ForWrite)
                              Dim l As Line = DirectCast(dbObj, Line)
                               l.EndPoint = New Point3d(l.EndPoint.X, l.EndPoint.Y, zeta)
                               l.StartPoint = New Point3d(l.StartPoint.X, l.StartPoint.Y, zeta)
                        Next
                        tr.Commit()
                    Catch ex As Exception
                        ed.WriteMessage(ex.ToString())
                        tr.Abort()
                    End Try
                End Using
            End Using
End Sub
First Time I call setzeta I've no problem, but the second time autocad crashes. I've an error in this line
                Using tr As Transaction = db.TransactionManager.StartTransaction (NullReferenceException)
Really crash hapen also after the first time I execute SetZeta, if I try to save the drawing
Where is the mistake?
12 REPLIES 12
Message 2 of 13
khoa.ho
The mistake may be from misusage of transaction.Abort(). It may call transaction.Commit() after that. I cleaned up your code and it works flawlessly in AutoCAD 2014. I will test this code in AutoCAD 2010 at my home machine.
Here is your working code in AutoCAD 2014:
<CommandMethod("SETZETA")> _
    ed.Regen()
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim filterForLine As TypedValue() = {New TypedValue(0, "LINE")}
            Dim sf As New SelectionFilter(filterForLine)
            Try
                If pSelRes.Status = PromptStatus.OK Then
                    Dim objIdArray As ObjectId() = pSelRes.Value.GetObjectIds()
                    Next
                    tr.Commit()
                End If
            Catch ex As System.Exception
                'tr.Abort();
            End Try
        End Using
    End Using
End Sub
Message 3 of 13
in reply to: khoa.ho
Yes, your code seems to work fine
Now I'm triyng to use the same code for fifferent object, circle arc, spline, blockreference
No problem a part blockreference. For this object I obtain the same error. Why?
    ed.Regen()
            Dim filterForLine As TypedValue() = {New TypedValue(0, "BLOCKREFERENCE")}
            Try
                        Dim l As blockreference = DirectCast(dbObj, blockreference)
                        l.Position = New Point3d(l.Position.X, l.Position.Y, zeta)
                    Next
                    tr.Commit()
                End If
                'tr.Abort();
            End Try
        End Using
    End Using
End Sub
Message 4 of 13
khoa.ho
TypedValue uses DxfName of BlockReference which is INSERT.
Change your code as the following and it will work:
TypedValue[] filterForLine = { new TypedValue(0, "INSERT") };
Message 5 of 13
Unfortunatly I've still that problem, even applying your suggestion.
Cause seems to be the line
It's seems that I can't change Position, or at least I dont't change it in correct way
Message 6 of 13
khoa.ho
The code works at my end. I am not sure why it did not work on your code. BlockReference.Position is a read and write property so you can get and set it. I don't have AutoCAD 2010 at my work office so cannot test your code.
Message 7 of 13
hgasty1001
If your block it's not in the WCS you will need to use a transformation matrix , see an example here: Move a Block Reference.
Gaston Nunez
Message 8 of 13
khoa.ho
in reply to: hgasty1001
Gaston is right to use BlockReference.TransformBy(Matrix3d.Displacement(new Vector(0,0,z)) to relocate the compound object such as BlockReference. Changing Position property does not make sense. Thank you.
Message 9 of 13
Thank's to all for your answer and help. Unfortunatly I've always the same problem, BUT really I don't have Autocad 2010, but Autocad Mechanical 2010
I've tryied your code with Autocad and It works fine, My problem is just with mechanical. Can you explain me the difference? And there is a solution also for mechanical?
Message 10 of 13
Basically when I execute my code second time I obtain an error NullReferenceException at the line
(only with Autocad mechanical and only with blockreference)
If I execute my code just one time,when I try to save drawing Autocad crashes
Message 11 of 13
khoa.ho
I don't have AutoCAD Mechanical 2010 to try it out. Did you try to run your code on Mechanical 2010 for your very simple block (only basic lines), which does not have any Mechanical entities? What I am guessing is your block has some custom objects which work on AutoCAD vanilla but not work on AutoCAD Mechanical when you perform BlockReference.TransformBy
It would be good if you re-post your latest code and a sample drawing to test on other machines of readers in this forum.
Message 12 of 13
hgasty1001
The last code you showed it's a mess:
1.- I'm not sure what kind of entity are you looking for as this line:
misguide Khoa.ho to correctly point that "BLOCKREFERENCE" dosn't exists and you have to use "INSERT" instead, but the filteForLine show that you are looking for lines, so it's no clear your aim. If they are lines then you have to change "INSERT" for "LINE".
2.-Lines doesn't have a property called "position", they have StartPoint and Endpoint, but again, to properly move an entity you have to use matrix transform as this:
Dim fromPoint as point3d=...your base point for displacemente here
dim toPoint as point3d=... your destination point here
Dim m3d as Matrix3D=Matrix3d.Displacement(fromPoint.GetVectorTo(toPoint))
MyEntity.TransformBy(m3d)
MyEntity can be any entity object instance
3.- I don't know of any graphic entity that CAN'T be transformed using the matrix3D method, and given that Entity it's the base class for BlockReference it should work on them too (and lines too)
Please show your last code.
Gaston Nunez
Message 13 of 13
Ok, there's a little bit of confusion
I have a lot of drawings imported from an old 2D cad (gbg). This cad doesn't have Z coordinates, just X,Y When I converted these drawings in dwg format, many objects assumed Z=0, but for many others Z was a different value (positive or negative). Of course this is a big problem, so I'm trying to built a dll with a command (SETZETA) to change Z coordinates to 0 for all objects
At the beginning I tried to change Z for Lines. then for other kind of object. No problem till Blockreference. Attached my full code
Probably this problem is caused from some mechanical custom object. Maybe I found the block that caused the problem (A0X2 attached). I don't know the english name. It's connect to the title drawing, It's the dimension of paper sheet
I hope I was more clear now 🙂
”Boost
