.NET
Autocad 2010 and Net Framework 4
3 REPLIES 3
2259 Views, 3 Replies
Hi All,
Is there any way to run *.dll application built under Net Framework 4 VS2010. I don't want to change Net Framework configuration.
3 REPLIES 3
Amremad
i think you can't use framework 4 .
only use framework 3.5
You can check the below link which is useful for to select AutoCAD version and .NET Framework.
http://spiderinnet1.typepad.com/blog/2011/11/versions-of-autocad-net-framework-runtime-and-visual-st...
BlackBox_
Unless your plug-in uses AcCoreMgd.dll (Core Console), or .NET 4.0 Framework specific Types that are not available to .NET 3.5, you *should* be able to simply copy your source code files into a AutoCAD .NET 2010-2012 Wizard project and compile to .NET 3.5 without issue.
"How we think determines what we do, and what we do determines what we get."
”Boost
