.NET
Active Contributor
ditran
Message 1 of 4 (362 Views)
Autocad 2010 and Net Framework 4
362 Views, 3 Replies
04-04-2013 12:15 AM
Hi All,
Is there any way to run *.dll application built under Net Framework 4 VS2010. I don't want to change Net Framework configuration.
Amremad
Message 2 of 4 (347 Views)
Re: Autocad 2010 and Net Framework 4
04-04-2013 01:40 AM in reply to: ditran
i think you can't use framework 4 .
only use framework 3.5
mzakiralam
Message 3 of 4 (287 Views)
04-15-2013 02:40 AM in reply to: ditran
You can check the below link which is useful for to select AutoCAD version and .NET Framework.
http://spiderinnet1.typepad.com/blog/2011/11/versions-of-autocad-net-framework-runtime-and-visual-st...
Distinguished Mentor
BlackBox_
Message 4 of 4 (259 Views)
04-17-2013 10:24 AM in reply to: ditran
Unless your plug-in uses AcCoreMgd.dll (Core Console), or .NET 4.0 Framework specific Types that are not available to .NET 3.5, you *should* be able to simply copy your source code files into a AutoCAD .NET 2010-2012 Wizard project and compile to .NET 3.5 without issue.
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
