Hi All,
Is there any way to run *.dll application built under Net Framework 4 VS2010. I don't want to change Net Framework configuration.
You can check the below link which is useful for to select AutoCAD version and .NET Framework.
Unless your plug-in uses AcCoreMgd.dll (Core Console), or .NET 4.0 Framework specific Types that are not available to .NET 3.5, you *should* be able to simply copy your source code files into a AutoCAD .NET 2010-2012 Wizard project and compile to .NET 3.5 without issue.
"How we think determines what we do, and what we do determines what we get."
