.NET
AutoCAD 2006 reference in VB 2005
10 REPLIES 10
Message 1 of 11
606 Views, 10 Replies
I am a new VB 2005 programmer that is converting from VB6. Many of my VB6
programs do the following:
I reference AutoCAD 2006 Type Library then under the
Option Explicit
Public MyAcad As AutoCAD.AcadApplication
Public ThisDrawing As AutoCAD.AcadDocument
In VB2005 I try the same thing and get Type AutoCAD.AcadApplication is not
defined
So I tried:
Public MyAcad As AutoDesk.AutoCAD.Interop.AcadApplication
Public ThisDrawing As AutoDesk.AutoCAD.Interop..AcadDocument
The MyAcad will run but the ThisDrawing still does not.
Any help would be appreciated!!
10 REPLIES 10
Message 2 of 11
I have created the function as show beneath in VB.Net 2003, it functions wel:
Friend Function DrawLine2D(ByVal StartPoint As Point2d, ByVal EndPoint As Point2d, ByVal Layer As AcadLayer) As AcadLine
Dim acadApp As AcadApplication
Dim acadDoc As AcadDocument
Dim nLine As AcadLine
Try
acadApp = CType(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, AcadApplication)
acadApp.Visible = True
acadDoc = acadApp.ActiveDocument
acadDoc.Application.Visible = True
nLine = acadDoc.ModelSpace.AddLine(Point2DToArray3D(StartPoint), Point2DToArray3D(EndPoint))
nLine.Layer = Layer.Name
Return nLine
Catch ex As Exception
MessageBox.Show(ex.ToString)
Return nLine
End Try
End Function
Maybe it helps you, otherwise come back again
Harold van Aarsen
Message 3 of 11
I tried:
I am using the COM reference of AutoCAD 2006 Type Library.
Should I be using something else.
When I do the above AcadApplication & AcadDocument are not recognised.
I better stop writing applications. I thought VB6 to VB.Net was suppose to
be a seamless transition. Sorry I am venting a little.
Nate
wrote in message news:5017208@discussion.autodesk.com...
wel:
Try
acadApp =
AcadApplication)
nLine =
Return nLine
Return nLine
End Try
End Function
Harold van Aarsen
Message 4 of 11
Did you import the name spaces for referenced autacad libraries? If not, following may help.
You need to include “Imports…….” statement at the beginning of the file where other ‘Imports’ statement are.
In Visual Studiio 2003, to find out what namespaces you need to include, expand ‘References’ under your ‘Solution’ in SolutionExplorer. Select the reference and then check its Properties in the Properties window. In the name field you will find something like this “Autodesk.AutoCad….”. This is what you need to Import.
If you do not import referenced namespaces, you will have to use statement like this:
Dim app as Autodesk.AutoCAD.Interop.AcadApplication
kr
Message 5 of 11
Here is exactly what I am trying:
Public Class Form1
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As
System.EventArgs) Handles Button1.Click
Dim MyAcad As Autodesk.AutoCAD.Interop.AcadApplication
Dim ThisDrawing As Autodesk.AutoCAD.Interop.AcadDocument
ThisDrawing = MyAcad.ActiveDocument ' (I get an error here stating MyAcad
has not been set)
MsgBox(ThisDrawing.Name)
End Sub
End Class
"Nate Hunter" wrote in message
news:5019338@discussion.autodesk.com...
I tried:
Nate
wel:
Try
acadApp =
AcadApplication)
nLine =
Return nLine
Return nLine
End Try
End Function
Harold van Aarsen
Message 6 of 11
VB6 to VB.NET is not a seamless transition. For more info.
http://msdn.microsoft.com/vbrun/staythepath/additionalresources/upgradingvb6/
Also have you thought about learning AutoCAD's .NET API rather than continuing to use ActiveX.
Regards - Nathan
Message 7 of 11
In .Net, VB behaves a bit differently.
When you Dim an object, the actual object is not created. To ceate an object after you have Declared the object, you need to do the following.
MyAcad = New Autodesk.AutoCAD.Interop.AcadApplication (this creates the application object)
ThisDrawing = MyAcad.Documents.Open("drawing.dwg, false, mypassword")
Open method requires filename, ReadOnlyFlag (true or false depending on your requirement) and password ("Nothing" if none exists)
Hope this helps.
(This code example corresponds to Autocad 2005 libraries. Ido not have Autocad 2006)
kr Message was edited by: Khalique
Message 8 of 11
I would love to lean AutoCAD's .Net API. Is there any documentation out
there I could look at. I am a strong VB6 programmer that is trying to get
into the .Net side of things. All my programs are all designed around
AutoCAD & Access but the main focus is on AutoCAD. So if there is
documentation out there that could help me I would love to get my hands on
it.
I currently only have VBA books for AutoCAD.
Thanks for all your help
wrote in message news:5019465@discussion.autodesk.com...
Regards - Nathan
Message 9 of 11
I have found my solution!! Thanks for all your input. Here is what I did:
Public Class Form1
MyAcad = GetObject(, "AutoCAD.Application.16")
End Sub
End Class
I would still be interested in any books or documentation any one could
point me to for VB.Net & AutoCAD
news:5019916@discussion.autodesk.com...
it.
Regards - Nathan
Message 10 of 11
The .NET documentation is currently part of the ObjectARX documentation located here.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=773180
And here are some labs.
http://discussion.autodesk.com/thread.jspa?messageID=4859028
Regards - Nathan
Message 11 of 11
Using GetObject(, "AutoCAD.Application.16") is a bad idea as if there are
multiple sessions of acad running you cannot garuntee that it will get the
acad you app is loaded in
in C# I use
Autodesk.AutoCAD.Interop.AcadApplication _AcadApp =
(AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplic
ation;
or VB
Dim _AcadApp Autodesk.AutoCAD.Interop.AcadApplication =
Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
Mark
news:5020349@discussion.autodesk.com...
Public Class Form1
End Sub
End Class
it.
Regards - Nathan
”Boost
