.NET
Valued Contributor
mindofcat
Message 1 of 6 (678 Views)
ATTSYNC in VB.NET
678 Views, 5 Replies
11-22-2013 11:28 AM
Hi all,
Does anyone know what the dot net equivalent is for attsync?
I use invisible attributes in the block references created by my dot net code, but I just noticed a strange AutoCAD behaviour:
Right-clicking on the block with attributes, and selecting the 'Edit Block in-place' option correctly displays the hidden attributes, making it possible for them to be deleted.
However, after deleting all the attributes and saving the ref edit, I right-click on the same block again, this time to check if it still has attibutes; and it does, even though I deleted all the attributes! There seems to be some sort of 'held-in-memory' issue here, which, after I did some research, I discovered that the ATTSYNC command is perfect for purging those deleted attributes from the block reference, AFTER they have been physically deleted.
The problem is, how do I implement this ATTSYNC command in my dot net code, without using sendcommand?
I found a thread on this forum regarding this issue, which led me to the swamp; but then the code I found there is in F#, and so I was wondering if anyone knows of a simple VB.NET way of mimicking the AutoCAD ATTSYNC command?
Many thanks...
Cat
Here's a simple and 'brute force' method which erases the existing AttributeReferences from the inserted BlockReferences and adds them new ones from the BlockTableRecord AttributeDefinitions.
The SynchronizeAttributes() method is defined as an extension method for the BlockTableRecord type so that it can be called as an instance method of this type.
Example (assuming btr is a BlocTableRecord instance) : btr.SynchronizeAttributes()
C# code
using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using AcRx = Autodesk.AutoCAD.Runtime;
namespace AttSyncSample
public static class ExtensionMethods
public static void SynchronizeAttributes(this BlockTableRecord target)
if (target == null)
throw new ArgumentNullException("btr");
Transaction tr = target.Database.TransactionManager.TopTransaction;
if (tr == null)
throw new AcRx.Exception(ErrorStatus.NoActiveTransactions);
RXClass attDefClass = RXClass.GetClass(typeof(AttributeDefinition));
List<AttributeDefinition> attDefs = new List<AttributeDefinition>();
foreach (ObjectId id in target)
if (id.ObjectClass == attDefClass)
AttributeDefinition attDef = (AttributeDefinition)tr.GetObject(id, OpenMode.ForRead);
attDefs.Add(attDef);
foreach (ObjectId id in target.GetBlockReferenceIds(true, false))
BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForWrite);
br.ResetAttributes(attDefs);
if (target.IsDynamicBlock)
foreach (ObjectId id in target.GetAnonymousBlockIds())
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
foreach (ObjectId brId in btr.GetBlockReferenceIds(true, false))
BlockReference br = (BlockReference)tr.GetObject(brId, OpenMode.ForWrite);
private static void ResetAttributes(this BlockReference br, List<AttributeDefinition> attDefs)
TransactionManager tm = br.Database.TransactionManager;
Dictionary<string, string> attValues = new Dictionary<string, string>();
foreach (ObjectId id in br.AttributeCollection)
if (!id.IsErased)
AttributeReference attRef = (AttributeReference)tm.GetObject(id, OpenMode.ForWrite);
attValues.Add(attRef.Tag, attRef.TextString);
attRef.Erase();
foreach (AttributeDefinition attDef in attDefs)
AttributeReference attRef = new AttributeReference();
attRef.SetAttributeFromBlock(attDef, br.BlockTransform);
if (attValues.ContainsKey(attDef.Tag))
attRef.TextString = attValues[attDef.Tag.ToUpper()];
br.AttributeCollection.AppendAttribute(attRef);
tm.AddNewlyCreatedDBObject(attRef, true);
VB code
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Module ExtensionMethods
<System.Runtime.CompilerServices.Extension> _
Public Sub SynchronizeAttributes(target As BlockTableRecord)
If target Is Nothing Then
Throw New ArgumentNullException("btr")
End If
Dim tr As Transaction = target.Database.TransactionManager.TopTransaction
If tr Is Nothing Then
Throw New Exception(ErrorStatus.NoActiveTransactions)
End If
Dim attDefClass As RXClass = RXClass.GetClass(GetType(AttributeDefinition))
Dim attDefs As New List(Of AttributeDefinition)()
For Each id As ObjectId In target
If id.ObjectClass = attDefClass Then
Dim attDef As AttributeDefinition = DirectCast(tr.GetObject(id, OpenMode.ForRead), AttributeDefinition)
attDefs.Add(attDef)
End If
Next
For Each id As ObjectId In target.GetBlockReferenceIds(True, False)
Dim br As BlockReference = DirectCast(tr.GetObject(id, OpenMode.ForWrite), BlockReference)
Next
If target.IsDynamicBlock Then
For Each id As ObjectId In target.GetAnonymousBlockIds()
Dim btr As BlockTableRecord = DirectCast(tr.GetObject(id, OpenMode.ForRead), BlockTableRecord)
For Each brId As ObjectId In btr.GetBlockReferenceIds(True, False)
Dim br As BlockReference = DirectCast(tr.GetObject(brId, OpenMode.ForWrite), BlockReference)
Next
Next
End If
End Sub
Private Sub ResetAttributes(br As BlockReference, attDefs As List(Of AttributeDefinition))
Dim tm As TransactionManager = br.Database.TransactionManager
Dim attValues As New Dictionary(Of String, String)()
For Each id As ObjectId In br.AttributeCollection
If Not id.IsErased Then
Dim attRef As AttributeReference = DirectCast(tm.GetObject(id, OpenMode.ForWrite), AttributeReference)
attRef.Erase()
End If
Next
For Each attDef As AttributeDefinition In attDefs
Dim attRef As New AttributeReference()
If attValues IsNot Nothing AndAlso attValues.ContainsKey(attDef.Tag) Then
attRef.TextString = attValues(attDef.Tag.ToUpper())
End If
tm.AddNewlyCreatedDBObject(attRef, True)
Next
End Sub
End Module
_gile
Message 2 of 6 (628 Views)
Re : ATTSYNC in VB.NET
11-23-2013 10:01 AM in reply to: mindofcat
C# code
using System;
            if (target == null)
            if (tr == null)
                if (!id.IsErased)
                    attRef.Erase();
VB code
        End If
        End If
                attDefs.Add(attDef)
            End If
        Next
        Next
                Next
            Next
        End If
    End Sub
                attRef.Erase()
            End If
        Next
            End If
        Next
    End Sub
End Module
Gilles Chanteau
Valued Contributor
mindofcat
Message 3 of 6 (583 Views)
11-25-2013 10:10 AM in reply to: _gile
Many thanks, Gilles... your code worked the magic!
_gile
Message 4 of 6 (575 Views)
11-25-2013 10:41 AM in reply to: mindofcat
You're welcome.
if you want it to work with mtext attributes, in the ResetAttributes method, replace:
with,
C#
    attRef.IsMTextAttribute ? attRef.MTextAttribute.Contents : attRef.TextString);
VB
attValues.Add( _
    attRef.Tag, _
    If(attRef.IsMTextAttribute, attRef.MTextAttribute.Contents, attRef.TextString))
Gilles Chanteau
_gile
Message 5 of 6 (542 Views)
11-26-2013 06:07 AM in reply to: _gile
You can find a better implementation (works with multiline attributes, constant attributes, dynamic blocks) at TheSwamp:
http://www.theswamp.org/index.php?topic=31859.msg508802#msg508802
Gilles Chanteau
Valued Contributor
mindofcat
Message 6 of 6 (529 Views)
11-26-2013 07:31 AM in reply to: _gile
Quite right it is, worked like a charm! many thanks again!
