.NET
AttributeReference Justification Issue - 2nd try
2 REPLIES 2
artem.voskanian
229 Views, 2 Replies
When I'm appending AttributeReference to a newly added BlockReference, attributes seems to be ignoring their justification as defined in AttributeDefinition. They all come in with the default lower left side justification. However, if I edit this inserted block in AutoCad, Attributes jump to their defined justification.
I do use SetAttributeFromBlock method, as well as trying to setting the WorkingDatabase to the AttributeReference's, but that didn't seem to resolve the issue.
2 REPLIES 2
in reply to: artem.voskanian
Is the Database that contains the objects the
current database (e.g., the WorkingDatabase
property of the HostApplicationServices class) ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5606456@discussion.autodesk.com...
Thanks Tony!
I was setting the WorkingDatabase to my attref's database (following your answer to a similar posting), but you just mentioned the key word "current". Suddenly it clicked for me. I'm actually creating a new drawing by starting a new database, so all I had to do was to set the working database to my new database, do the attribute thing and set it back.
Many thanks!
”Boost
