.NET
AttributeCollection from a non-placed block
2 REPLIES 2
jdsmit
495 Views, 2 Replies
I need to get the AttributeCollection of a named block wich is not been placed in the drawing, but it does exist
        Dim paaltype As String
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim acDocEd As Editor = acDoc.Editor
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                paaltype = "paal01"
                Dim acBlkTbl As BlockTable
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                If acBlkTbl.Has(paaltype) Then
                    ‘block exist, how to get the attributecollection
                End If
            acTrans.Dispose()
        End Using
2 REPLIES 2
norman.yuan
in reply to: jdsmit
If by "AttributeCollection", you mean the class Autodesk.AutoCAD.DatabaseServices.AttribueCollection, then, you cannot: non-placed block is a block definition, a BlockTableRecord, it DOES not hold an AttributeCollection - a collection of AttributeReference. BlockTableRecord itself is a collection of entities, including possible 0 or more AttributeDefinitions. To see if a block has attrbutions and collect a list of them, you do:
Dim attrs As New List(Of AttributeDefinition)()
    Dim blk As BlockTableRecord=acBlkTbl(paaltype)
    If blk.HasAttributeDefinitions Then
        For Each id As ObjectId in blk
            Dim att As AttributeDefinition=TryCast(acTrans.GetObject(id,OpenMode.ForRead),AttributeDefinition)
            If att IsNot Nothing Then
                attrs.Add(att)
            End
        Next
    End If
End If
MessageBox.Show(attr.Count & " attributes found in block " & paaltype)
Norman Yuan
Drive CAD With Code
jdsmit
in reply to: norman.yuan
Thanks a lot.
With some modifications it work perfect.
Here is my working code:
        lvPalen.Items.Clear()
            For i = 1 To 36
                paaltype = "paal" + Format(i, "00")
                    Dim blk As BlockTableRecord = acBlkTbl(paaltype).GetObject(OpenMode.ForRead)
                        For Each id2 As ObjectId In blk
                            Dim att As AttributeDefinition = TryCast(acTrans.GetObject(id2, OpenMode.ForRead), AttributeDefinition)
                                If att.Tag.ToUpper = "AFMETING" Then lvPalen.Items.Add(att.TextString, i - 1)
                            End If
                        Next
                    End If
                End If
            Next
            acTrans.Dispose()
        End Using
”Boost
