.NET
Attribute will sometimes move when changing it value
3 REPLIES 3
wowens63
610 Views, 3 Replies
AutoCad 2012...when using db.ReadDwgFile(MyDwg, IO.FileShare.ReadWrite, False, "")
to change Attribute Values the Attribute will sometimes move if i open the Drawing and run a audit on the drawing and regen then it moves back to is correct location
but if i use Dim NewDoc As Document = Application.DocumentManager.Open(DocumentName, false) and run the same code there is no problem.
so my question is why does it do that?
Sub SetAttributeValues(ByVal BlockReferenceID As ObjectId, ByVal AttributeTagsValues As Dictionary(Of String, String))         Dim DwgEditor As Editor = TryCast(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor, Editor)
        Using myTrans As Transaction = BlockReferenceID.Database.TransactionManager.StartTransaction             Try                 Dim myBRef As BlockReference = TryCast(BlockReferenceID.GetObject(OpenMode.ForRead), BlockReference)                 Dim myAttCollection As AttributeCollection = TryCast(myBRef.AttributeCollection, AttributeCollection)                 For Each myAttRefID As ObjectId In myAttCollection                     Dim myAttRef As AttributeReference = TryCast(myAttRefID.GetObject(OpenMode.ForWrite), AttributeReference)                     If AttributeTagsValues.ContainsKey(myAttRef.Tag) Then                         myAttRef.TextString = AttributeTagsValues(myAttRef.Tag)                     End If                 Next                 myTrans.Commit()             Catch ex As Autodesk.AutoCAD.Runtime.Exception                 DwgEditor.WriteMessage(ex.Message + vbLf + ex.StackTrace)                 myTrans.Abort()             End Try         End Using     End Sub
and it only seems to do that on Attributes that are set to justificated = center
3 REPLIES 3
khoa.ho
in reply to: wowens63
You are missing code to adjust the block attribute position after changing its value: AttributeReference.AdjustAlignment(db)
Try this code:
Public Sub SetAttributeValues(blockReferenceID As ObjectId, attributeTagsValues As Dictionary(Of String, String))
	Dim dwgEditor As Editor = TryCast(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor, Editor)
	Dim db As Database = blockReferenceID.Database
	Dim workDb As Database
	Using myTrans As Transaction = db.TransactionManager.StartTransaction()
		Try
			Dim myBRef As BlockReference = TryCast(blockReferenceID.GetObject(OpenMode.ForRead), BlockReference)
			If myBRef IsNot Nothing Then
				Dim myAttCollection As AttributeCollection = myBRef.AttributeCollection
					Dim myAttRef As AttributeReference = DirectCast(myAttRefID.GetObject(OpenMode.ForWrite), AttributeReference)
					If attributeTagsValues.ContainsKey(myAttRef.Tag) Then
						myAttRef.TextString = attributeTagsValues(myAttRef.Tag)
						' Adjust alignment of this attribute
						workDb = HostApplicationServices.WorkingDatabase
						HostApplicationServices.WorkingDatabase = db
						myAttRef.AdjustAlignment(db)
						HostApplicationServices.WorkingDatabase = workDb
				Next
			myTrans.Commit()
			dwgEditor.WriteMessage(ex.Message + vbLf + ex.StackTrace)
			myTrans.Abort()
		End Try
	End Using
End Sub
-Khoa
wowens63
in reply to: khoa.ho
thank you
khoa.ho
You are welcome.
-Khoa
”Boost
