.NET
Attach image using RealDWG .NET API
3 REPLIES 3
1491 Views, 3 Replies
I am developing a program in which I need to write come points, lines, polygons, and attach an Image to DWG file. I am using the RealDWG .NET API and I able to write other entities except the Image.
I tried the code as mentioned in this article. So, when I ran the code and found that the code is crashing when setting the "SourceFileName" of "RasterImageDef" class and the exception says "eFileAccessErr". I checked and the access is fine with that image file.
So, I just wanted to know whether is it possible to attach the image using RealDWG .NET API or I am just wasting my time with this API and if so, then please let me know why I am getting the exception.
Pankaj Sachdeva
Tags (1)
3 REPLIES 3
Dale.Bartlett
Kean's code to which you refer is quite old (2010). I have done a lot with RealDWG, but not for some time. When I checked, raster imaging was not part of that project. As you are aware, RealDWG is only lacking display and print functionality (Document/Editor), so I would have thought that attaching a raster image to the database would be straightforward (famous last words).
Below is some code that is more up to date, but not converted to RealDWG (HostApplicationServices.WorkingDatabase). From this site:
RasterImagesNET2015
Good luck. Please post some code when you get it runnng.
Dale
<code>
[CommandMethod("AttachRasterImage")]
public void AttachRasterImage()
// Get the current database and start a transaction
Database db = AcadApp.DocumentManager.MdiActiveDocument.Database;
using (Transaction tr = db.TransactionManager.StartTransaction())
// Define the name and image to use
string strImgName = "WorldMap";
string strFileName = "C:\\AutoCAD\\Sample\\VBA\\WorldMap.TIF";
RasterImageDef acRasterDef;
bool bRasterDefCreated = false;
ObjectId acImgDefId;
// Get the image dictionary
ObjectId acImgDctID = RasterImageDef.GetImageDictionary(db);
// Check to see if the dictionary does not exist, it not then create it
if (acImgDctID.IsNull)
acImgDctID = RasterImageDef.CreateImageDictionary(db);
// Open the image dictionary
DBDictionary acImgDict = tr.GetObject(acImgDctID, OpenMode.ForRead) as DBDictionary;
// Check to see if the image definition already exists
if (acImgDict.Contains(strImgName))
acImgDefId = acImgDict.GetAt(strImgName);
acRasterDef = tr.GetObject(acImgDefId,
OpenMode.ForWrite) as RasterImageDef;
else
// Create a raster image definition
RasterImageDef acRasterDefNew = new RasterImageDef();
// Set the source for the image file
acRasterDefNew.SourceFileName = strFileName;
// Load the image into memory
acRasterDefNew.Load();
// Add the image definition to the dictionary
acImgDict.UpgradeOpen();
acImgDefId = acImgDict.SetAt(strImgName, acRasterDefNew);
tr.AddNewlyCreatedDBObject(acRasterDefNew,true);
acRasterDef = acRasterDefNew;
bRasterDefCreated =true;
// Open the Block table for read
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
// Open the Block table record Model space for write
BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
// Create the new image and assign it the image definition
using (RasterImage acRaster = new RasterImage())
acRaster.ImageDefId = acImgDefId;
// Use ImageWidth and ImageHeight to get the size of the image in pixels (1024 x 768).
// Use ResolutionMMPerPixel to determine the number of millimeters in a pixel so you
// can convert the size of the drawing into other units or millimeters based on the
// drawing units used in the current drawing.
// Define the width and height of the image
Vector3d width;
Vector3d height;
// Check to see if the measurement is set to English (Imperial) or Metric units
if (db.Measurement == MeasurementValue.English)
width =new Vector3d((acRasterDef.ResolutionMMPerPixel.X * acRaster.ImageWidth) / 25.4, 0, 0);
height =new Vector3d(0, (acRasterDef.ResolutionMMPerPixel.Y * acRaster.ImageHeight) / 25.4, 0);
else
width =new Vector3d(acRasterDef.ResolutionMMPerPixel.X * acRaster.ImageWidth, 0, 0);
height =new Vector3d(0, acRasterDef.ResolutionMMPerPixel.Y * acRaster.ImageHeight, 0);
// Define the position for the image
Point3d insPt = new Point3d(5.0, 5.0, 0.0);
// Define and assign a coordinate system for the image's orientation
CoordinateSystem3d coordinateSystem = new CoordinateSystem3d(insPt, width * 2, height * 2);
acRaster.Orientation = coordinateSystem;
// Set the rotation angle for the image
acRaster.Rotation = 0;
// Add the new object to the block table record and the transaction
btr.AppendEntity(acRaster);
tr.AddNewlyCreatedDBObject(acRaster,true);
// Connect the raster definition and image together so the definition
// does not appear as "unreferenced" in the External References palette.
RasterImage.EnableReactors(true);
acRaster.AssociateRasterDef(acRasterDef);
if (bRasterDefCreated)
acRasterDef.Dispose();
// Save the new object to the database
tr.Commit();
// Dispose of the transaction
<code>
______________
Yes, I'm Satoshi.
in reply to: Dale.Bartlett
The code below throws up an Autocad Runtime Exception eFileAccessErr at the highlighted line in the code below.
I am using RealDwg and AutoCAD Civil 3D 2014.
Please help me to resolve this issue.
Jainendra
matthias_beyer
I had the same issue. What you have to do is update the FindFile function in your RealDwgInitialize class.
public override string FindFile(string fileName, Database database, FindFileHint hint)
            if (fileName.Contains(".") == false)
                string extension = "";
                switch (hint)
                    case FindFileHint.Default:
                        break;
                    case FindFileHint.FontFile:
                        break;
                    case FindFileHint.CompiledShapeFile:
                        extension = ".shx";
                        break;
                    case FindFileHint.TrueTypeFontFile:
                        extension = ".ttf";
                        break;
                    case FindFileHint.EmbeddedImageFile:
                        break;
                    case FindFileHint.XRefDrawing:
                        extension = ".dwg";
                        break;
                    case FindFileHint.PatternFile:
                        break;
                    case FindFileHint.ArxApplication:
                        extension = ".dbx";
                        break;
                    case FindFileHint.FontMapFile:
                        extension = ".fmp";
                        break;
                    case FindFileHint.UnderlayFile:
                        break;
                    default:
                        break;
                if (extension.Length == 0)
                    Console.WriteLine("RealDWG Init - FindFile - Need to handle this.");
                fileName += extension;
            return SearchPath(database, fileName);
private string SearchPath(Database database, string specifiedFileName)
            FileInfo fileName = new FileInfo(specifiedFileName);
            if (fileName.Exists == true)
                return fileName.FullName;
            // get the application folder to check there
            DirectoryInfo appFolder = new DirectoryInfo(Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location));
            fileName = new FileInfo(Path.Combine(appFolder.FullName, fileName.Name));
            // check autodesk shared
            DirectoryInfo adeskSharedFolder = new DirectoryInfo(Path.Combine(Environment.GetEnvironmentVariable("ProgramFiles"), @"Common Files\Autodesk Shared"));
            fileName = new FileInfo(Path.Combine(adeskSharedFolder.FullName, fileName.Name));
            // check our fonts folder
            DirectoryInfo fontsFolder = new DirectoryInfo(Path.Combine(appFolder.FullName, "Fonts"));
            fileName = new FileInfo(Path.Combine(fontsFolder.FullName, fileName.Name));
            // check the system fonts folder
            DirectoryInfo systemFontsFolder = new DirectoryInfo(Path.Combine(Environment.GetEnvironmentVariable("SystemRoot"), "Fonts"));
            fileName = new FileInfo(Path.Combine(systemFontsFolder.FullName, fileName.Name));
            if (database != null)
                DirectoryInfo currentDwgFolder = new DirectoryInfo(Path.GetDirectoryName(database.Filename));
                fileName = new FileInfo(Path.Combine(currentDwgFolder.FullName, specifiedFileName));
                DirectoryInfo currentOriginalDwgFolder = new DirectoryInfo(Path.GetDirectoryName(database.OriginalFileName));
                fileName = new FileInfo(Path.Combine(currentOriginalDwgFolder.FullName, specifiedFileName));
            return "";
”Boost
