.NET
.NET
New Member
0 Kudos
Post 1 of 5
Attach image from VB.NET to AutoCad
414 Views, 4 Replies
01-17-2012 10:11 AM
Hello!
I have just started to programming VB.NET with AutoCad but can´t find any information about how to attach a image from a userform commandbuton into AutoCad. I have programming in VBA before but can´t find any solution for inserting pictures in VB.NET. Is it possible to use the "imageattach" with attributes? or -image command? Or should I use Rasterimage?
I want a image (*.jpg*) file to appear in AutoCad when I press the Commandbutton in my Form.
I hope you understand what I mean. And excuse,if my english is bad!
44 Kudos
Post 2 of 5
Re: Attach image from VB.NET to AutoCad
01-17-2012 12:31 PM in reply to: lejros
search for  RasterImage   in http://through-the-interface.typepad.com
New Member
0 Kudos
Post 3 of 5
01-17-2012 02:07 PM in reply to: lejros
Hi! Thanks for the link. Have looked there and can only find codes for C#. What library do I need to import for doing rasterimage?
37 Kudos
Post 4 of 5
01-17-2012 02:22 PM in reply to: lejros
http://www.developerfusion.com/tools/convert/csharp-to-vb/
(defun botsbuildbots() (botsbuildbots))
Valued Mentor
30 Kudos
Post 5 of 5
01-17-2012 03:09 PM in reply to: lejros
Reference library is acdbmgd. Rasterimagedef is a member of Autodesk.AutoCAD.DatabaseServices.
My code samples are limited.  You should search here for more.
ObjectID of dictionary is
Dim imagedictionaryId As ObjectId = RasterImageDef.GetImageDictionary(db)
Dictionary is
Dim imagedictionary As DBDictionary = tx.GetObject(imagedictionaryId, OpenMode.ForWrite)
