.NET
Associative Hatch Error
10 REPLIES 10
Message 1 of 11
wesbird
1728 Views, 10 Replies
I am writing a function to create Hatch. Everything works just fine except Associative. if I put the
oHatch.Associative = true;
get a error message:
eNotInDatabase
It will work if I remove this line.
does anybody know how to fix it? thank you very much.
Here is the code:
public static Hatch CreateHatch(Entity pline, BlockTableRecord btr, short HatchColor,
string HatchLayer, string HatchPattern, double HatchScale, double HatchAngle, bool HatchAssociate)
if (pline == null) return null;
Database db = HostApplicationServices.WorkingDatabase;
Transaction trans = db.TransactionManager.StartTransaction();
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId,OpenMode.ForWrite);
bool IsSolid = (HatchPattern == "SOLID");
LayerLibrary.IsLayerLocked(HatchLayer);
if (HatchPattern.Substring(0,3).Equals("ISO")) {HatchPattern = "ACAD_" + HatchPattern;}
ObjectId oId;
if (HatchAssociate)
Entity pline2 = (Entity)trans.GetObject(pline.ObjectId,OpenMode.ForWrite);
oId = pline2.ObjectId;
else { oId = pline.ObjectId;}
ObjectIdCollection ObjIds = new ObjectIdCollection();
ObjIds.Add(oId);
Hatch oHatch = new Hatch();
try
oHatch.SetHatchPattern(HatchPatternType.PreDefined,HatchPattern);
oHatch.AppendLoop(0, ObjIds);
oHatch.Layer = HatchLayer;
oHatch.ColorIndex = HatchColor;
oHatch.Associative = HatchAssociate;
if (!IsSolid)
oHatch.PatternAngle = HatchAngle;
oHatch.PatternScale = HatchScale;
oHatch.EvaluateHatch(true);
btr.AppendEntity(oHatch);
trans.AddNewlyCreatedDBObject(oHatch,true);
trans.Commit();
catch (System.Exception caught)
// ddebug
ed.WriteMessage(caught.Message.ToString());
oHatch = null;
finally
trans.Dispose();
return oHatch;
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
10 REPLIES 10
Message 2 of 11
ChrisArps
in reply to: wesbird
The error message is telling you exactly what to do.
The hatch must be added to the database first so the objectId of the hatch can be used to establish the relation between it and the boundary entities.
Try calling AddNewlyCreated first then set the associative flag to true.
You also should call Trans.Abort() in your catch block and also call oHatch.Dispose when you are done with the hatch object.
Chris Arps
Message 3 of 11
wesbird
Thank you, Chris.
I move
right after
it do create Hatch without error message but the hatch is non-associated.
so I add
after Associative
still not associated.
I go back and check AutoCAD Managed Class Reference, under AcDbHatch Class, there are sample code in C++, which did not required Associate after add to database.
here is the code:
Acad::ErrorStatus acqHatch1()
AcDbHatch* pHatch = new AcDbHatch();
// Set hatch plane
AcGeVector3d normal(0.0, 0.0, 1.0);
pHatch->setNormal(normal);
pHatch->setElevation(0.0);
// Set non associative hatch
pHatch->setAssociative(Adesk::kFalse);
// Set hatch pattern to SolidFill type
pHatch->setPattern(AcDbHatch::kPreDefined, "SOLID");
// Set hatch style to kNormal
pHatch->setHatchStyle(AcDbHatch::kNormal);
// Append an external loop (rectangle) to hatch boundary
pHatch->appendLoop(AcDbHatch::kExternal, vertexPts, vertexBulges);
// Append an internal circular loop to hatch boundary
AcGeIntArray edgeTypes;
AcGeVoidPointerArray edgePtrs;
edgeTypes.append(AcDbHatch::kCirArc);
edgePtrs.append((void*)cirArc);
pHatch->appendLoop(AcDbHatch::kDefault, edgePtrs, edgeTypes);
// Elaborate solid fill
pHatch->evaluateHatch();
Any idea? Thank you very much.
Wes
Update:
In same help file, Property Associative is wrapped from AcDbHatch::associative and AcDbHatch::setAssociative,
in help item for AcDbHatch::setAssociative
"This function sets the associativity flag to true or false for the hatch entity. To create an associative hatch entity, you must use this function and set the associativity flag to true before you begin to build the boundary loops using the appendLoop(loopType, dbObjIds) or insertLoopAt(loopIndex, loopType, dbObjIds) functions. "
so I move
before
error message:
eNotInDatabase
Message was edited by: weslleywang Message was edited by: weslleywang
Message 4 of 11
ChrisArps
Since you are adding loops by objectid, then the hatch must be added to the database before calling appendLoop.
If you set the associative property to true, then the hatch tries to setup a reactor/relationship to the polyline.
Try AddObject, set associative to true, then Addloops.
Chris Arps
Message 5 of 11
wesbird
Not working. error message: eAmbiguousOutput
Here is the code:
try
if (!IsSolid)
// todo
trans.Commit();
oHatch.Dispose();
Message 6 of 11
ChrisArps
There is a sample of adding a hatch in ObjectArx sdk, but it works differently in dotnet.
Here is VB code that works:
Public Sub TestHatch()
' method was gleaned from ObjectArx2006 samples, file EntMakeTest.cpp
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim selOpts As New PromptSelectionOptions()
Dim res As PromptSelectionResult
selOpts.SingleOnly = True
selOpts.MessageForAdding = "Select a closed polyline"
res = ed.GetSelection(selOpts)
If res.Status <> PromptStatus.OK Then Return
Dim selId As ObjectId = res.Value.GetObjectIds(0)
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
Dim trans As Transaction = tm.StartTransaction
Try
Dim objIds As New ObjectIdCollection()
objIds.Add(selId)
Dim hat As New Hatch()
With hat
.SetDatabaseDefaults()
.Layer = "0"
.PatternAngle = 0.0
.PatternScale = 100.0 ' I use ADT Imperial, so this works mo betta
' DEFECT: must set pattern last or angle and scale do not work
.SetHatchPattern(HatchPatternType.PreDefined, "ANGLE")
End With
Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead, False)
Dim btr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, False)
btr.AppendEntity(hat)
trans.AddNewlyCreatedDBObject(hat, True)
'enum HatchLoopType
'kDefault 0 The loop type hasn't been specified yet.
' It turns to a "real" value as soon as some real loops get created.
'kExternal 1 A loop that consists of external entities (derived from AcDbEntity and owned by
' an AcDbDatabase). The hatch might be associative to these entities.
'kPolyline 2 The hatch loop consists of a polyline (AcGe geometry, not AcDb geometry).
'kDerived 4 A loop that was derived by AutoCAD's boundary tracer from a picked point.
'kTextbox 8 A loop that consists of a box around an existing text object (AcDbText).
'kOutermost 0x10 The outermost loop of this hatch.
'kNotClosed 0x20 A loop that is not closed.
'kSelfIntersecting 0x40 A loop that intersects with itself.
'kTextIsland 0x80 Text loops that are surrounded by even number of outer loops.
' Text island loops are avoided when performing solid fill.
hat.Associative = True
hat.AppendLoop(1, objIds)
hat.EvaluateHatch(False)
hat.Dispose()
trans.Commit()
Catch ex As Exception
MsgBox(ex.Message)
trans.Abort()
Finally
trans.Dispose()
tm.Dispose()
End Try
End Sub
Message 7 of 11
wesbird
Thank you, this time it works.
Wes
Message 8 of 11
ghethco
I'm trying to add a hatch to a block I'm creating.  Whenever I try to set the hatch's "PatternAngle", I get a 'eInvalidInput' exception.  I'm just trying to set it to 45 degrees, which works fine creating a hatch manually in the GUI.
Here's the code:
Try
    Dim myDWG As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
    Dim myDB As Database = myDWG.Database
    Dim myTrans As Transaction = myDB.TransactionManager.StartTransaction
    Dim BlockName As String = "MyBlock"
    Dim BasePoint As New Point3d(0, 0, 0)
    Dim docloc As DocumentLock = myDWG.LockDocument
    Using (docloc)
    Using (myTrans)
        Layers.SetLayer("MODULES-HATCH")
        Dim MyBT As BlockTable = CType(myTrans.GetObject(myDB.BlockTableId, OpenMode.ForWrite), BlockTable)
        For Each ObjID As ObjectId In MyBT
        Dim MyBTR As BlockTableRecord = CType(myTrans.GetObject(ObjID, OpenMode.ForWrite), BlockTableRecord)
        If (MyBTR.Name = BlockName) Then
            Dim MyPL2 As New Polyline       ' bounding rectangle
            MyPL2.AddVertexAt(0, New Point2d(LowerLeft.X + 1, LowerLeft.Y + 1), 0, 0, 0)
            MyPL2.AddVertexAt(1, New Point2d(UpperRight.X - 1, LowerLeft.Y + 1), 0, 0, 0)
            MyPL2.AddVertexAt(2, New Point2d(UpperRight.X - 1, UpperRight.Y - 1), 0, 0, 0)
            MyPL2.AddVertexAt(3, New Point2d(LowerLeft.X + 1, UpperRight.Y - 1), 0, 0, 0)
            MyPL2.AddVertexAt(4, New Point2d(LowerLeft.X + 1, LowerLeft.Y + 1), 0, 0, 0)
            MyBTR.AppendEntity(MyPL2)
            myTrans.AddNewlyCreatedDBObject(MyPL2, True)
            Dim IDS As ObjectIdCollection = New ObjectIdCollection()
            IDS.Add(MyPL2.ObjectId)
            Dim MyHatch As Hatch = New Hatch()
            MyBTR.AppendEntity(MyHatch)
            myTrans.AddNewlyCreatedDBObject(MyHatch, True)
            MyHatch.SetDatabaseDefaults()
            'MyHatch.PatternAngle = 45.0  <--- causes "eInvalidInput" exception
            MyHatch.PatternScale = 64.0
            MyHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI37")
            MyHatch.Associative = True
            MyHatch.AppendLoop(HatchLoopTypes.Outermost, IDS)
            MyHatch.EvaluateHatch(False)
            MyHatch.Dispose()
        'EntLib.Debug("Block Name = " & MyBTR.Name)
        Next
        myTrans.Commit()
    End Using
    End Using
Catch ex As System.Exception
    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message)
End Try
Message 9 of 11
ghethco
in reply to: ghethco
BTW, the angle itself doesn't matter, even with "0.0" as the angle, still get the exception.  Also tried 45 degrees converted to radians (Math.PI / 180.0) * 45.0.  Same result.
Gary
Message 10 of 11
Hallex
Try add PatternAngle right after this line:
Just an idea, sorry, I can't check it now
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 11 of 11
Mep09Developer
”Boost
