.NET
GeoSchaap
Message 1 of 6 (639 Views)
ArxWizards install problem
639 Views, 5 Replies
06-05-2011 08:16 AM
I'm trying to install the ArxWizards, but keep on reciving this error attached. I'm working with autocad 2012 and visual studio 2010.
any suggestion?
Can you please try setting the User Access Control Settings (UAC) to "Never Notify" and then start the ArxWizards installer ?
A system restart may be required after the UAC setting is modified.
Hope this helps.
Cheers,
Balaji
Developer Technical Services
Autodesk Developer Network
The AutoCAD .Net Wizard is different from the ObjectARX Wizard.
You can get it from the Developer Center. Here is the link :
AutoCAD .Net Wizard
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
Cheers,
Balaji
ADN Support Specialist
Balaji_Ram
Message 2 of 6 (618 Views)
Re: ArxWizards install problem
06-05-2011 08:17 PM in reply to: GeoSchaap
Hope this helps.
Cheers,
Balaji
Balaji
GeoSchaap
Message 3 of 6 (611 Views)
06-05-2011 10:58 PM in reply to: GeoSchaap
hi Balaji,
thanks for respond. Installation did work after I did what you said, so thanks. Now, I enter the Visual Studio starting a new project, but in the New Project dialog/Visual C# Projects there is no “AutoCAD Managed C# Project” template. :smileysad:
Balaji_Ram
Message 4 of 6 (606 Views)
06-05-2011 11:18 PM in reply to: GeoSchaap
AutoCAD .Net Wizard
Cheers,
Balaji
Balaji
GeoSchaap
Message 5 of 6 (603 Views)
06-06-2011 12:09 AM in reply to: Balaji_Ram
Balaji, you are tha man! It works! thanks...
New Member
karlmt
Message 6 of 6 (305 Views)
04-01-2013 06:17 PM in reply to: Balaji_Ram
thank,it is almost not been mention in chinese web site,you help me a lot.
