.NET
ARXDBG
6 REPLIES 6
HJohn1
1884 Views, 6 Replies
ARXDBG
Can someone post a compiled ARXDBG.arx program for AutoCAD 2010.  I can't compile it myself.  Thanks in advance.
6 REPLIES 6
Alexander.Rivilis
in reply to: HJohn1
You can download x86 version of ARXDBG 2010 from this link: http://through-the-interface.typepad.com/files/arxdbg_2010.zip
Facebook | Twitter | LinkedIn
Expert Elite Member
michael_vanhoose
in reply to: HJohn1
Is there a 64bit version somewhere.  I can't compile without getting a error too.
Try attached version for x86 & x64.
Expert Elite Member
Tags (1)
michael_vanhoose
in reply to: HJohn1
Thanks, worked great!
HJohn1
in reply to: Alexander.Rivilis
Thank you very much Alexander.  Really appreciated!
StephenPreston
in reply to: HJohn1
I recommend MgdDbg over ArxDbg - that's downloadable from Kean Walmsley's blog too.
Cheers,
Stephen Preston
Autodesk Developer Network
Cheers,
Stephen Preston
”Boost
