.NET
ArxDbg.arx Windows 7
2 REPLIES 2
SRSDS
1751 Views, 2 Replies
I have been using a file ArxDbg.arx to "SNOOP" database entries or entity xdata.
The file won't load in Windows 7. I guess that there's a diferent version needed but I can't find it.
2 REPLIES 2
BlackBox_
in reply to: SRSDS
ObjectARX is both environment and database version specific, meaning that there is a different ARX file for each AutoCAD 2013 32-bit, and AutoCAD 2013 64-bit (two ARX files).
Windows 7 has nothing to do with this... The only correlation to Windows 7 might be if you previously had a 32-bit OS (i.e., Vista, XP, etc.), and are now using Windows 7 64-bit... But again, that's an environment (processing) issue.
In any event, ArxDbg (ObjectARX) and MgdDbg (.NET) are both great tools, and can be downloaded in Autoloader .bundle format from your local ".bundle Thrift Shop" here.
Direct links to .ZIP files:
Autodesk DWG ArxDBG.bundle.zip
Autodesk DWG MgdDBG.bundle.zip
... Snoop Civil 3D 2014 Database is now available as well, for those who may be interested.
"How we think determines what we do, and what we do determines what we get."
SRSDS
in reply to: BlackBox_
Thankyou!
And to whoever created it I take my hat off.
”Boost
