Hey guys,
I'm trying to prompt a user to create a rectangle to use as a selection box to later layout blocks. The native rectangle command in AutoCAD 2012 is perfect but i need to get the area, length and width of the rectangle...is there a way that i could use something like editor.selectlast to figure this out?
Cheers
Vince
Solved by _gile. Go to Solution.
Not sure about A2012 but maybe this helps
<CommandMethod("Selast")> _ Public Sub testbox() Dim doc As Document = Application.DocumentManager.MdiActiveDocument() Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim res As PromptSelectionResult res = ed.SelectLast Try Using tr As Transaction = db.TransactionManager.StartTransaction Dim ent As Entity = tr.GetObject(res.Value.GetObjectIds(0), OpenMode.ForRead) Dim ecs As Extents3d = ent.GeometricExtents Dim leng As Double = ecs.MaxPoint.X - ecs.MinPoint.X Dim wid As Double = ecs.MaxPoint.Y - ecs.MinPoint.Y Dim ar As Double = leng * wid ed.WriteMessage(vbCr + "Length: {0}; Width: {1}; Area: {2}", leng, wid, ar) End Using Catch exs As System.Exception ed.WriteMessage(exs.Message & vbLf & exs.StackTrace) Finally End Try End Sub
~'J'~
Thanks Hallex, i'm going to try this out now and i'll report back. Would it be easier to just use the "area" command in autoCAD as my selection box as it provides all the info right away as well as a nice interface? If so, is it still possible to return the values for area, length and width into my code?
Cheers
Vince
I've just worked this back into C# but am running into an error on this line:
Entity ent = tr.GetObject(resr.Value.GetObjectIds(0), OpenMode.ForRead) as Entity;
The error I get is that "No overload for method 'GetObjectIDs' takes 1 arguments" and "Argument 1: cannot convert from 'Autodesk.AutoCAD.DatabaseServices.ObjectId[] to 'Autodesk.AutoCAD.DatabaseServices.ObjectId'
Is this something ridiculously simple??
Cheers
Vince
// Option 1 ... User Selects Rectangle as Shape if (sres.StringResult == "rect") { Document docr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Database dbr = doc.Database; Editor edr = doc.Editor; Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; PromptSelectionResult resr = new PromptSelectionResult(); resr = ed.SelectLast(); acDoc.SendStringToExecute("._rectangle ", true, false, false); Transaction tr = db.TransactionManager.StartTransaction(); using (tr) { //Entity ent = tr.GetObject(resr.Value.GetObjectIds(0), OpenMode.ForRead) as Entity; Entity ent = tr.GetObject(resr.Value.GetObjectIds(0), OpenMode.ForRead) as Entity; Extents3d ecs = ent.GeometricExtents; double leng = ecs.MaxPoint.X - ecs.MinPoint.X; double wid = ecs.MaxPoint.Y - ecs.MinPoint.Y; double ar = leng * wid; edr.WriteMessage("Length = " + leng); edr.WriteMessage("Width = " + wid); edr.WriteMessage("Area = " + ar); }
You can stay avoid SendStringToExecute I think
Perhaps it will help as well:
<CommandMethod("Selast")> _ Public Sub testbox() Dim doc As Document = Application.DocumentManager.MdiActiveDocument() Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim res As PromptSelectionResult res = ed.SelectLast Try Using tr As Transaction = db.TransactionManager.StartTransaction Dim ent As Entity = tr.GetObject(res.Value.GetObjectIds(0), OpenMode.ForRead) Dim ecs As Extents3d = ent.GeometricExtents Dim leng As Double = ecs.MaxPoint.X - ecs.MinPoint.X Dim wid As Double = ecs.MaxPoint.Y - ecs.MinPoint.Y Dim ar As Double = leng * wid ed.WriteMessage(vbCr + "Length: {0}; Width: {1}; Area: {2}", leng, wid, ar) Dim pres As PromptSelectionResult 'pres = ed.SelectCrossingWindow(ecs.MinPoint, ecs.MaxPoint) ''<-- you can add the filter there, e.g.: ''----------------------------------------------------------------------------------------------------'' Dim filterList(,) As Object = New Object(,) {{-4, "<or"}, {0, "Line"}, {0, "Polyline"}, {0, "Insert"}, {0, "Circle"}, {0, "Circle"}, {-4, "or>"}} '' и т. д. Dim tvs(filterList.GetUpperBound(0)) As TypedValue For i As Integer = 0 To filterList.GetUpperBound(0) tvs(i) = New TypedValue(Convert.ToInt32(filterList(i, 0)), filterList(i, 1)) Next Dim filt As SelectionFilter = New SelectionFilter(tvs) pres = ed.SelectCrossingWindow(ecs.MinPoint, ecs.MaxPoint, filt) ''<-- the filter added ''----------------------------------------------------------------------------------------------------'' If pres IsNot Nothing Then For Each selobj As SelectedObject In pres.Value Dim obj As Entity = tr.GetObject(selobj.ObjectId, OpenMode.ForRead) ed.WriteMessage(vbLf + obj.GetRXClass().DxfName) Next End If End Using Catch exs As System.Exception ed.WriteMessage(exs.Message & vbLf & exs.StackTrace) Finally End Try End Sub
~'J'~
You may avoid using SendStringToexecute because it doesn't run synchronously.
You can define a 'Rectangle' Type with the properties and method you need.
Here's an example:
public class Rectangle { // constructor public Rectangle(Point3d p1, Point3d p2) { LowerLeft = new Point3d(Math.Min(p1.X, p2.X), Math.Min(p1.Y, p2.Y), 0.0); UpperRight = new Point3d(Math.Max(p1.X, p2.X), Math.Max(p1.Y, p2.Y), 0.0); Length = UpperRight.X - LowerLeft.X; Width = UpperRight.Y - LowerLeft.Y; Area = Length * Width; } // public read only properties public Point3d LowerLeft { get; private set; } public Point3d UpperRight { get; private set; } public double Length { get; private set; } public double Width { get; private set; } public double Area { get; private set; } public SelectionSet CrossingSelectionSet { get { return Select(true); } } public SelectionSet WindowSelectionSet { get { return Select(false); } } // public method, draws the rectangle in the current space. public void Draw() { Database db = HostApplicationServices.WorkingDatabase; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite); using (Polyline pline = new Polyline()) { pline.AddVertexAt(0, new Point2d(LowerLeft.X, LowerLeft.Y), 0.0, 0.0, 0.0); pline.AddVertexAt(1, new Point2d(UpperRight.X, LowerLeft.Y), 0.0, 0.0, 0.0); pline.AddVertexAt(2, new Point2d(UpperRight.X, UpperRight.Y), 0.0, 0.0, 0.0); pline.AddVertexAt(3, new Point2d(LowerLeft.X, UpperRight.Y), 0.0, 0.0, 0.0); pline.Closed = true; btr.AppendEntity(pline); tr.AddNewlyCreatedDBObject(pline, true); } tr.Commit(); } } // public static method, creates a new instance of Rectangle if the user specifies two points public static Rectangle Create() { Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; PromptPointResult ppr = ed.GetPoint("\nFirst corner: "); if (ppr.Status == PromptStatus.Cancel) return null; Point3d pt = ppr.Value; ppr = ed.GetCorner("\nSecond corner: ", pt); if (ppr.Status == PromptStatus.Cancel) return null; Matrix3d ucs = ed.CurrentUserCoordinateSystem; return new Rectangle(pt.TransformBy(ucs), ppr.Value.TransformBy(ucs)); } // private method, returns the selection set private SelectionSet Select(bool crossing) { Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor; Matrix3d wcs = ed.CurrentUserCoordinateSystem.Inverse(); return crossing ? ed.SelectCrossingWindow(LowerLeft.TransformBy(wcs), UpperRight.TransformBy(wcs)).Value : ed.SelectWindow(LowerLeft.TransformBy(wcs), UpperRight.TransformBy(wcs)).Value; } }
Then, using this type, you can prompt the user to draw a rectangle the same wat as the native AutoCAD Command, get the data you need (length, width and area), use the rectangle to get a selection set.
Here's a little example:
[CommandMethod("test")] public void test() { Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; Rectangle rect = Rectangle.Create(); if (rect == null) return; SelectionSet ss = rect.WindowSelectionSet; ed.SetImpliedSelection(ss); rect.Draw(); ed.WriteMessage("\nLength = {0} Width = {1} Area = {2}", rect.Length, rect.Width, rect.Area); }
My shot:
<CommandMethod("DREC")> _ Public Sub DrawRect() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = HostApplicationServices.WorkingDatabase() Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim p1, p2 As Point3d Using acTrans As Transaction = db.TransactionManager.StartTransaction() Dim acSSPrompt As PromptPointResult = doc.Editor.GetPoint("Select First Point: ") If acSSPrompt.Status = PromptStatus.OK Then p1 = acSSPrompt.Value acSSPrompt = doc.Editor.GetCorner(vbCrLf + "Select Second Point: ", p1) If acSSPrompt.Status = PromptStatus.OK Then p2 = acSSPrompt.Value Else MsgBox("Invalid point") Exit Sub End If Else MsgBox("Invalid point") Exit Sub End If Dim v1 As Vector3d Dim theta As Double Dim p3, p4 As Point2D Dim a, b, l, s As Double Dim d As Double v1 = p1.GetVectorTo(p2) theta = v1.GetAngleTo(Vector3d.XAxis, Vector3d.ZAxis.Negate()) d = p1.DistanceTo(p2) a = d * Math.Cos(theta) b = d * Math.Sin(theta) l = 2 * (Math.Abs(a) + Math.Abs(b)) s = Math.Abs(a * b) If s <= 0.001 Then MsgBox("Degenerated Rectangle, try again", vbCritical) Exit Sub End If p3 = New Point3d(p1.X + a, p1.Y) p4 = New Point3d(p1.X, p1.Y + b) Dim pl As New Polyline pl.AddVertexAt(0, New Point2d(p1.X, p1.Y), 0, 0, 0) pl.AddVertexAt(1, p3, 0, 0, 0) pl.AddVertexAt(2, New Point2d(p2.X, p2.Y), 0, 0, 0) pl.AddVertexAt(3, p4, 0, 0, 0) pl.Closed = True Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead) Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite) acBlkTblRec.AppendEntity(pl) acTrans.AddNewlyCreatedDBObject(pl, True) ed.WriteMessage(vbCrLf + "Rectangle length:=" + l.ToString + vbCrLf) ed.WriteMessage("Rectangle Area:=" + s.ToString + vbCrLf) ed.WriteMessage("Width:=" + Math.Abs(a).ToString + vbCrLf) ed.WriteMessage("Height:=" + Math.Abs(b).ToString + vbCrLf) acTrans.Commit() End Using End Sub
Thanks to everyone for their input! _gile thank you very much, with your example i got it working perfectly, much appreciated!!!!
