.NET
Area, Length and Width of last object created
7 REPLIES 7
Message 1 of 8
vince1327
2116 Views, 7 Replies
Hey guys,
I'm trying to prompt a user to create a rectangle to use as a selection box to later layout blocks. The native rectangle command in AutoCAD 2012 is perfect but i need to get the area, length and width of the rectangle...is there a way that i could use something like editor.selectlast to figure this out?
Cheers
Vince
7 REPLIES 7
Message 2 of 8
Hallex
in reply to: vince1327
Not sure about A2012 but maybe this helps
 <CommandMethod("Selast")> _
    Public Sub testbox()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument()
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim res As PromptSelectionResult
        res = ed.SelectLast
        Try
            Using tr As Transaction = db.TransactionManager.StartTransaction
                Dim ent As Entity = tr.GetObject(res.Value.GetObjectIds(0), OpenMode.ForRead)
                Dim ecs As Extents3d = ent.GeometricExtents
                Dim leng As Double = ecs.MaxPoint.X - ecs.MinPoint.X
                Dim wid As Double = ecs.MaxPoint.Y - ecs.MinPoint.Y
                Dim ar As Double = leng * wid
                ed.WriteMessage(vbCr + "Length: {0}; Width: {1}; Area: {2}", leng, wid, ar)
            End Using
        Catch exs As System.Exception
            ed.WriteMessage(exs.Message & vbLf & exs.StackTrace)
        Finally
        End Try
    End Sub
~'J'~
Message 3 of 8
vince1327
in reply to: Hallex
Thanks Hallex, i'm going to try this out now and i'll report back. Would it be easier to just use the "area" command in autoCAD as my selection box as it provides all the info right away as well as a nice interface? If so, is it still possible to return the values for area, length and width into my code?
Cheers
Vince
Message 4 of 8
vince1327
in reply to: Hallex
I've just worked this back into C# but am running into an error on this line:
Entity ent = tr.GetObject(resr.Value.GetObjectIds(0), OpenMode.ForRead) as Entity;
The error I get is that  "No overload for method 'GetObjectIDs' takes 1 arguments" and "Argument 1: cannot convert from 'Autodesk.AutoCAD.DatabaseServices.ObjectId[] to 'Autodesk.AutoCAD.DatabaseServices.ObjectId'
Is this something ridiculously simple??
Cheers
Vince
// Option 1 ... User Selects Rectangle as Shape
            if (sres.StringResult == "rect")
                Document docr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                Database dbr = doc.Database;
                Editor edr = doc.Editor;
                Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                PromptSelectionResult resr = new PromptSelectionResult();
                resr = ed.SelectLast();
                acDoc.SendStringToExecute("._rectangle ", true, false, false);
                   Transaction tr = db.TransactionManager.StartTransaction();
                   using (tr)
                       //Entity ent = tr.GetObject(resr.Value.GetObjectIds(0), OpenMode.ForRead) as Entity;
                       Extents3d ecs = ent.GeometricExtents;
                       double leng = ecs.MaxPoint.X - ecs.MinPoint.X;
                       double wid = ecs.MaxPoint.Y - ecs.MinPoint.Y;
                       double ar = leng * wid;
                       edr.WriteMessage("Length = " + leng);
                       edr.WriteMessage("Width = " + wid);
                       edr.WriteMessage("Area = " + ar);
Message 5 of 8
Hallex
You can stay avoid SendStringToExecute I think
Perhaps it will help as well:
        res = ed.SelectLast
        Try
                Dim pres As PromptSelectionResult
                'pres = ed.SelectCrossingWindow(ecs.MinPoint, ecs.MaxPoint) ''<-- you can add the filter there, e.g.:
                Dim filterList(,) As Object = New Object(,) {{-4, "<or"}, {0, "Line"}, {0, "Polyline"}, {0, "Insert"}, {0, "Circle"}, {0, "Circle"}, {-4, "or>"}} '' и т. д.
                Dim tvs(filterList.GetUpperBound(0)) As TypedValue
                For i As Integer = 0 To filterList.GetUpperBound(0)
                    tvs(i) = New TypedValue(Convert.ToInt32(filterList(i, 0)), filterList(i, 1))
                Next
                Dim filt As SelectionFilter = New SelectionFilter(tvs)
                pres = ed.SelectCrossingWindow(ecs.MinPoint, ecs.MaxPoint, filt) ''<-- the filter added
                If pres IsNot Nothing Then
                    For Each selobj As SelectedObject In pres.Value
                        Dim obj As Entity = tr.GetObject(selobj.ObjectId, OpenMode.ForRead)
                        ed.WriteMessage(vbLf + obj.GetRXClass().DxfName)
                    Next
                End If
            End Using
        Finally
        End Try
    End Sub
~'J'~
Message 6 of 8
_gile
You may avoid using SendStringToexecute because it doesn't run synchronously.
You can define a 'Rectangle' Type with the properties and method you need.
Here's an example:
        public class Rectangle
            // constructor
            public Rectangle(Point3d p1, Point3d p2)
                LowerLeft = new Point3d(Math.Min(p1.X, p2.X), Math.Min(p1.Y, p2.Y), 0.0);
                UpperRight = new Point3d(Math.Max(p1.X, p2.X), Math.Max(p1.Y, p2.Y), 0.0);
                Length = UpperRight.X - LowerLeft.X;
                Width = UpperRight.Y - LowerLeft.Y;
                Area = Length * Width;
            // public read only properties
            public Point3d LowerLeft { getprivate set; }
            public Point3d UpperRight { getprivate set; }
            public double Length { getprivate set; }
            public double Width { getprivate set; }
            public double Area { getprivate set; }
            public SelectionSet CrossingSelectionSet
                get { return Select(true); }
            public SelectionSet WindowSelectionSet
                get { return Select(false); }
            // public method, draws the rectangle in the current space.
            public void Draw()
                Database db = HostApplicationServices.WorkingDatabase;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    using (Polyline pline = new Polyline())
                        pline.AddVertexAt(0, new Point2d(LowerLeft.X, LowerLeft.Y), 0.0, 0.0, 0.0);
                        pline.AddVertexAt(1, new Point2d(UpperRight.X, LowerLeft.Y), 0.0, 0.0, 0.0);
                        pline.AddVertexAt(2, new Point2d(UpperRight.X, UpperRight.Y), 0.0, 0.0, 0.0);
                        pline.AddVertexAt(3, new Point2d(LowerLeft.X, UpperRight.Y), 0.0, 0.0, 0.0);
                        pline.Closed = true;
                        btr.AppendEntity(pline);
                        tr.AddNewlyCreatedDBObject(pline, true);
                    tr.Commit();
            // public static method, creates a new instance of Rectangle if the user specifies two points
            public static Rectangle Create()
                Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
                PromptPointResult ppr = ed.GetPoint("\nFirst corner: ");
                if (ppr.Status == PromptStatus.Cancel)
                    return null;
                Point3d pt = ppr.Value;
                ppr = ed.GetCorner("\nSecond corner: ", pt);
                    return null;
                Matrix3d ucs = ed.CurrentUserCoordinateSystem;
                return new Rectangle(pt.TransformBy(ucs), ppr.Value.TransformBy(ucs));
            // private method, returns the selection set
            private SelectionSet Select(bool crossing)
                Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
                Matrix3d wcs = ed.CurrentUserCoordinateSystem.Inverse();
                return crossing ?
                    ed.SelectCrossingWindow(LowerLeft.TransformBy(wcs), UpperRight.TransformBy(wcs)).Value :
                    ed.SelectWindow(LowerLeft.TransformBy(wcs), UpperRight.TransformBy(wcs)).Value;
Then, using this type, you can prompt the user to draw a rectangle the same wat as the native AutoCAD Command, get the data you need (length, width and area), use the rectangle to get a selection set.
Here's a little example:
        [CommandMethod("test")]
        public void test()
            Rectangle rect = Rectangle.Create();
            if (rect == null)
                return;
            SelectionSet ss = rect.WindowSelectionSet;
            ed.SetImpliedSelection(ss);
            rect.Draw();
            ed.WriteMessage("\nLength = {0} Width = {1} Area = {2}", rect.Length, rect.Width, rect.Area);
Gilles Chanteau
GileCAD
GitHub
Message 7 of 8
hgasty1001
My shot:
<CommandMethod("DREC")> _
    Public Sub DrawRect()
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = HostApplicationServices.WorkingDatabase()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim p1, p2 As Point3d
        Using acTrans As Transaction = db.TransactionManager.StartTransaction()
            Dim acSSPrompt As PromptPointResult = doc.Editor.GetPoint("Select First Point: ")
            If acSSPrompt.Status = PromptStatus.OK Then
                p1 = acSSPrompt.Value
                acSSPrompt = doc.Editor.GetCorner(vbCrLf + "Select Second Point: ", p1)
                    p2 = acSSPrompt.Value
                Else
                    MsgBox("Invalid point")
                    Exit Sub
                End If
            Else
                Exit Sub
            End If
            Dim v1 As Vector3d
            Dim theta As Double
            Dim p3, p4 As Point2D
            Dim a, b, l, s As Double
            Dim d As Double
            v1 = p1.GetVectorTo(p2)
            theta = v1.GetAngleTo(Vector3d.XAxis, Vector3d.ZAxis.Negate())
            d = p1.DistanceTo(p2)
            a = d * Math.Cos(theta)
            b = d * Math.Sin(theta)
            l = 2 * (Math.Abs(a) + Math.Abs(b))
            s = Math.Abs(a * b)
            If s <= 0.001 Then
                MsgBox("Degenerated Rectangle, try again", vbCritical)
                Exit Sub
            End If
            p3 = New Point3d(p1.X + a, p1.Y)
            p4 = New Point3d(p1.X, p1.Y + b)
            Dim pl As New Polyline
            pl.AddVertexAt(0, New Point2d(p1.X, p1.Y), 0, 0, 0)
            pl.AddVertexAt(1, p3, 0, 0, 0)
            pl.AddVertexAt(2, New Point2d(p2.X, p2.Y), 0, 0, 0)
            pl.AddVertexAt(3, p4, 0, 0, 0)
            pl.Closed = True
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            acBlkTblRec.AppendEntity(pl)
            acTrans.AddNewlyCreatedDBObject(pl, True)
            ed.WriteMessage(vbCrLf + "Rectangle length:=" + l.ToString + vbCrLf)
            ed.WriteMessage("Rectangle Area:=" + s.ToString + vbCrLf)
            ed.WriteMessage("Width:=" + Math.Abs(a).ToString + vbCrLf)
            ed.WriteMessage("Height:=" + Math.Abs(b).ToString + vbCrLf)
            acTrans.Commit()
        End Using
    End Sub
Message 8 of 8
vince1327
in reply to: _gile
Thanks to everyone for their input! _gile thank you very much, with your example i got it working perfectly, much appreciated!!!!
”Boost
