.NET
arc.Normal = 0,0,-1
1 REPLY 1
641 Views, 1 Reply
arc.Normal = 0,0,-1
Dear all ,i need a big pleasure.
i have insert a dxf in my drawing and when i make the command "_list " a see
that someone arc or circle have the normal's Z value set to -1,but i see the
correct display
then the VBA Api i make the changement with the instruction :
if arc.normal.z=-1 then
arc.normal.z=1
arc.update
endif
when is finish i have correct normal and correct display
now i have rewrite for .NET Api with this code:
arc.normal=new acge.vectord3d(0,0,1)
end if
but this code don't work.
when i have finish i see the correct normal but the incorrect display.
Some help?
Thank's in advance
GPaolo
1 REPLY 1
I have resolved.
here the solution.
many thank's at all
GPaolo
Dim nulltransform As New AcGe.Matrix3dBuilder
nulltransform.ElementAt(0, 0) = 1
nulltransform.ElementAt(0, 1) = 0
nulltransform.ElementAt(0, 2) = 0
nulltransform.ElementAt(0, 3) = 0
nulltransform.ElementAt(1, 0) = 0
nulltransform.ElementAt(1, 1) = 1
nulltransform.ElementAt(1, 2) = 0
nulltransform.ElementAt(1, 3) = 0
nulltransform.ElementAt(2, 0) = 0
nulltransform.ElementAt(2, 1) = 0
nulltransform.ElementAt(2, 2) = -1 'VALUE SET TO CHANGE NORMAL
nulltransform.ElementAt(2, 3) = 0
nulltransform.ElementAt(3, 0) = 0
nulltransform.ElementAt(3, 1) = 0
nulltransform.ElementAt(3, 2) = 0
nulltransform.ElementAt(3, 3) = 1
If Arc.Normal.Z = -1 Then
Arc.TransformBy(nulltransform.ToMatrix3d)
"GPaolo" ha scritto nel messaggio
news:5256092@discussion.autodesk.com...
correct display
arc.normal.z=1
arc.update
endif
end if
Some help?
Thank's in advance
GPaolo
”Boost
