.NET
Active Contributor
2 Kudos
Post 1 of 6
Arc and CircularArc2d
687 Views, 5 Replies
02-26-2013 09:13 PM
Hello everyone.
I'm a bit riddled by how conversion between the two types should work and whether it is what should be done. As I trace boundary of a 2d figure ( editor.TraceBoundary( ... ) ) I get a collection with - say - one Polyline object.
When I want to extract an arc segment from the polyline, I am using (polyline.GetArcSegment2dAt( ... )). The object I get is of type CircularArc2d.
If I save this object somewhere and pull it back later, how can I have it drawn? So far I tried to convert CircularArc2d to Arc:
CircularArc2d carc = ...
Arc aarc = new Arc(
  Convertor.ToPoint3d(carc.Center),
  carc.Radius,
  carc.StartAngle,
  carc.EndAngle
But that didn't turn out well. The circular arc seems to determine its start by the start point, having start angle = 0, while the arc understands this zero as "start from polar zero radians, as seen from the center". I tried to set a start point to the arc:
Arc aarc = new Arc();
aarc.StartPoint = Convertor.ToPoint3d(carc.StartPoint);
aarc.EndPoint = Convertor.ToPoint3d(carc.EndPoint);
aarc.Center = Convertor.ToPoint3d(carc.Center);
But that produces exception saying that setting start point isn't implemented for the Arc type.
I can go for calculating the start/end angle for Arc, but something tells me there must be a more elegant and more precise way to trace arcs, save them externally and use them later. I could use a hand with this one.
Thanks!
WWFreeman wrote:
In the meantime, can you confirm there is no way we can actually extract Arc instead of CircularArc2d/3d from a Polyline?
Polyline.Explode produce Arcs and Lines.
Distinguished Mentor
91 Kudos
Post 2 of 6
Re: Arc and CircularArc2d
02-26-2013 10:07 PM in reply to: WWFreeman
It seems there is not an elegant solution, check this link: http://forums.autodesk.com/t5/NET/Create-Arc-with-StartPoint-EndPoint-Radius/m-p/3773066#M33369. Almost 50 lines of code to create an arc!
Another solution could be using editor.runcommand as implemented by TT in this link :RunCommand .
Gaston Nunez
Active Contributor
2 Kudos
Post 3 of 6
02-26-2013 10:14 PM in reply to: gasty1001
Gosh, yeah, that doesn't look neat. :smileyvery-happy:
Alright, I'll be having some 'fun' with this topic and then come back and mark this as solved if nobody else opposes.
Moderator
277 Kudos
Post 4 of 6
02-26-2013 10:32 PM in reply to: WWFreeman
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
2 Kudos
Post 5 of 6
02-26-2013 10:53 PM in reply to: Alexander.Rivilis
Right. In my case it was wrong to start using CircularArc2d type.
However, gasty's post has revealed me further very useful stuff. Thank you!
If I happen to write a CircularArc2d -> Arc converter, it will probably be posted here as I saw none.
Moderator
277 Kudos
Post 6 of 6
02-26-2013 10:58 PM in reply to: WWFreeman
You can cut CircularArc2d -> Arc converter from this post.
