.NET
Apply to layout" - how?
4 REPLIES 4
446 Views, 4 Replies
Following this article:
http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-basic.html
I have change something in this code, and I'm setting plot window area based on borders in layout.
Everything is ok.
One thing I want to have is to apply all my plot settings to the current layout - as I said, window area is set well, but in layout space I don't have good "paper area" (look at screenshot).
I have to go to the plot settings, set or unset (in example) centering plot and then click apply to layout. After that I have everything ok.
So, how can I from C# set paper area in layout space (I mean only this black part in layout).
Thanks.
4 REPLIES 4
folivier
This may help you, setup the *.dwt and the "Page Setup Manager" and follow the steps.
SENL1362
The easiest way i found so far is to switch layouts, i.e. set layout2 or Model active and then switch back.
All type of refreshes and regen's didn't.
vankhai-externe.nguyen
I also have the same issue : I change by code the plot setting but I'm not able to "Apply To Layout".
Does anyone have found the solution ?
Switch Layouts refreshes the layout by all the parameters are not applied
 I found the issue : you must specify  : CanonicalMediaName
IE : plotConfig.CanonicalMediaName = "ISO_expand_A0_(841.00_x_1189.00_MM)";
”Boost
