.NET
'ApplicationServices' is not a member of 'AutoCAD'
13 REPLIES 13
Message 1 of 14
RyanBotha
649 Views, 13 Replies
First off, you may have seen this before here...
http://forums.autodesk.com/t5/NET/Namespace-ApplicationServices-does-not-exist-in-Autodesk-AutoCAD/t...
However, that does work for me, not sure why. I'm using VB 2010 Express, and really enjoying it! When I add my references, acdbmgd and acmgd from AutoCAD 2012 folder, everything looks good. When I hit compile, i get the errors shown in the attachment.
What have I done wrong?
Thank you for your help.
Regards & Happy Easter
Ryan
13 REPLIES 13
Message 2 of 14
adadnet
in reply to: RyanBotha
hi ryan, just an idea, have you tried setting the reference path of the acmgd file to the downloaded, appropriate sdk folder (as opposed to the autodesk one)?
Message 3 of 14
RyanBotha
in reply to: adadnet
I had tried that, but to make sure, I tried it again, with not success. If I'm correct in understanding you, its the one that defaults to C:\ObjectARX 2012\inc
I also ran a repair on .NET framework 4., and ran the 3.5 SP1 install too. Nothing changed.
Hmmm, what now?
Message 4 of 14
RyanBotha
So, I found the advanced compiler options! It was set to '.NET 4 Framework Client Profile'. If I change it to .'NET Framework 4', it compiles, but doesn't run.
Error is thrown before form appears.
Message 5 of 14
adadnet
does acad2012 know that you are now targeting .net 4.0? i.e. have you allocated the acad configuration file on your system and changed version to 4.0?
Message 6 of 14
RyanBotha
I'm a bit rusty. And to be honest, have no idea what you just asked me Smiley Indifferent
How would I do that last bit. Apologies for the greeness! 😛
Message 7 of 14
adadnet
sorry, was a bit short.
on your main drive should be the autodesk file for your acad application and in there an acad configuration file (either .exe or .config). this config file contains the acad's target .net framework (and not much more) which should conform to the framework you set for you project, as you say 4.0 (and not be commented out); you can open and edit the config file e.g. with notepad
Message 8 of 14
RyanBotha
No Problem!
<configuration>
   <startup useLegacyV2RuntimeActivationPolicy="true">
      <supportedRuntime version="v4.0"/>
   </startup>
<!--All assemblies in AutoCAD are fully trusted so there's no point generating publisher evidence-->
   <runtime>
      <generatePublisherEvidence enabled="false"/>
   </runtime>
</configuration>
This is in a file called acad.exe.config. Presuming that is v4.0...
I'm runnning Win7 x64 if that makes a difference...
Message 9 of 14
adadnet
i'm stuck. recap: applicationservices namespace found after project's target framework set to 4.0; acad config file also 4.0; project compiles;
"...but doesn't run"- you start debugging but no feedback in the immediate window, hit breakpoints, any exceptions thrown etc?
Message 10 of 14
adadnet
Message 11 of 14
RyanBotha
Yeah, I am aware of the 'MyFirstPlugin'. I'll try compile on my home laptop, and see if its a machine issue. If not, I'll post a recap.
Thank you for your help!
Message 12 of 14
norman.yuan
The fact that it compiles but does not run, and the other clues from what you have sid in this thread inducate that your have an issue that is different from the other thread you mentioned:
You are doing a stand-alone VB.NET EXE project, aren't you?
If yes, then you CANNOT USE AutoCAD .NET API assemblies (acdbmgd.dll, acmgd.dll...), thus the error you got when trying to run your app.
For EXE app, you can only use AutoCAD COM API, or you can do Acad .NET API DLL project and expose it as COM (if you know what does that mean).
Message 13 of 14
RyanBotha
in reply to: norman.yuan
Norman, I think you've got it! I neglected to mention that its a standalone app, mostly incororating Excel to Inventor communication. I'm using the AutoCAD bit to update a title block.
Yikes, the smallest things get overlooked. Didn't even think to mention it.
I've got a vague idea of what you mean. Any links that I can follow or read though to guide me through it?
Thank you!
Message 14 of 14
RyanBotha
Appreciate the help and patience. I think I've stumbled upon the potential answer within AutoCAD Exchange. Just never knew what to search for. Case of 'you don't know what you don't know'. Thats why the forum is so helpful
 Smiley Happy
”Boost
