.NET
Valued Contributor
e.g.
Message 1 of 3 (135 Views)
Accepted Solution
application.MainWindow location
135 Views, 2 Replies
03-20-2014 11:28 AM
I am trying to update some code I used on Autocad 2012 and, in Autocad 2014, I don't know how to get the MainWindow location.
In Autocad 2012 I used Autocad.ApplicationServices.Application.MainWindow.Location. How can I get this location using Autocad 2014?
Thank you very much,
e.g.
*Expert Elite*
Keith.Brown
Message 2 of 3 (128 Views)
Re: application.MainWindow location
03-20-2014 12:08 PM in reply to: e.g.
I could be wrong but for 2014 i believe you need to reference accoremgd and then access the main window using the following two methods:
Autodesk.AutoCAD.ApplicationServices.Core.Application.MainWindow.SetLocation()
Autodesk.AutoCAD.ApplicationServices.Core.Application.MainWindow.GetLocation()
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Valued Contributor
e.g.
Message 3 of 3 (116 Views)
03-20-2014 12:31 PM in reply to: Keith.Brown
Yes, that's it, thank you very much.
e.g.
Announcements
Need installation help?
