.NET
Distinguished Contributor
wesbird
Message 1 of 2 (174 Views)
application is busy in customized version of Script Pro 2
174 Views, 1 Replies
11-21-2013 08:41 AM
I'm modified Script Pro 2 from autodesk lab. Now I have this problem, sometimes, I got this error message
"The message filter indicated that the application is busy. (Exception from HRESULT: 0x8001010A (RPC_E_SERVERCALL_RETRYLATER))"
at
object ret = ActiveDocument.GetType().InvokeMember(
"SendCommand",
BindingFlags.InvokeMethod,
null, ActiveDocument, OnedataArray
 or
short fd = (short)ActiveDocument.GetVariable("FILEDIA");
 ActiveDocument come from
ActiveDocument =
AcadDocuments.GetType().InvokeMember(
"Open",
null, AcadDocuments, ThreeVariable
I understand those are out-process call. Maybe AutoCAD is still doing something when it happens. right now I increase the wait time right before the call like:
Thread.Sleep(100) -> Thread.Sleep(500)
what should I do to avoid this problem.
Wes
I suggest you to use IsAcadQuiescent() before sending the command to AutoCAD. IsAcadQuiescent is implemented in ScriptPro specifically to check for AutoCAD state.
ADN Support Specialist
Virupaksha.aithal
Message 2 of 2 (132 Views)
Re: application is busy in customized version of Script Pro 2
11-25-2013 09:20 PM in reply to: wesbird
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
