.NET
Valued Contributor
scluna
Message 1 of 5 (355 Views)
API for Boundary of Region
355 Views, 4 Replies
01-20-2014 06:05 AM
Does anyone knows the api use for region. I am using Editor.Traceboundary but having problem. When I use Boundary command I notice that it has region boundary retention option in it. Is there an api for that?
Thanks and regrads
SCLuna
Hi Sherwin,
>>the only thing i notice that i need to zoom to extent the drawing to make the tracing works
This is as expected. The API is using the same internal code as the boundary command. It is using the graphics cache which means the geometry must be displayed on-screen for the algorithm to work. (Try running the boundary command on something that is off-screen, and you'll see the same thing).
ADN Support Specialist
Virupaksha.aithal
Message 2 of 5 (325 Views)
Re: API for Boundary of Region
01-20-2014 09:01 PM in reply to: scluna
Can you please share a non confidential drawing against which you are trying to create the boundary using Traceboundary API?
also, refer DevBlog which shows how to run boundary command in .NET @ http://adndevblog.typepad.com/autocad/2012/08/running-boundary-command-through-command-line-using-ne...
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Valued Contributor
scluna
Message 3 of 5 (302 Views)
01-21-2014 06:36 AM in reply to: Virupaksha.aithal
Hi Virupaksha,
I think I resolved the problem in the drawing using the traceboundary. the drawing contains a lot of visible layer so what i did is modify my program and set the visibility of the other layer to false, while the layer that i need to visibility is true then i execute the traceboundary. the only thing i notice that i need to zoom to extent the drawing to make the tracing works. I will still do further tracing.
I still not able to resolved Export to SDF version 2 using API of autocad 2013. Please see link of post:
http://forums.autodesk.com/t5/NET/Extract-SDF-2-in-autocad-net-API/m-p/4762195#M38749
SCLuna
Valued Contributor
scluna
Message 4 of 5 (298 Views)
01-21-2014 06:43 AM in reply to: Virupaksha.aithal
Here is a sample drawing
SCLuna
Board Manager
StephenPreston
Message 5 of 5 (285 Views)
01-21-2014 11:05 AM in reply to: scluna
Hi Sherwin,
Cheers,
Stephen Preston
