.NET
Active Contributor
murali.pandey
Message 1 of 3 (169 Views)
Aotocad Map Toolbar
169 Views, 2 Replies
04-19-2012 12:03 AM
Hi...
How can I create a toolbar (say with one button) in AutoCad Map by using C# (.Net object arx).
If any body can provide sample code ..will b much better.
Murali
Moderator
Alexander.Rivilis
Message 2 of 3 (157 Views)
Re: Aotocad Map Toolbar
04-19-2012 06:19 AM in reply to: murali.pandey
You can start from that post: http://forums.autodesk.com/t5/NET/Create-toolbar/m-p/1687527#M3911
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
murali.pandey
Message 3 of 3 (133 Views)
04-24-2012 11:06 PM in reply to: Alexander.Rivilis
Thanks!
One more thing ..I have to execute other command by clicking the added toolbar button.How can I do by using C#.
(I just want to the way how I can create the toolbar then how to load it and then how to excute the command on clicking the toolbar button using C#)
