.NET
Aotocad Map Toolbar
2 REPLIES 2
417 Views, 2 Replies
Aotocad Map Toolbar
Hi...
How can I create a toolbar (say with one button) in AutoCad Map by using C# (.Net object arx).
If any body can provide sample code ..will b much better.
Murali
2 REPLIES 2
Alexander.Rivilis
You can start from that post: http://forums.autodesk.com/t5/NET/Create-toolbar/m-p/1687527#M3911
Facebook | Twitter | LinkedIn
Expert Elite Member
in reply to: Alexander.Rivilis
Thanks!
One more thing ..I have to execute other command by clicking the added toolbar button.How can I do by using C#.
(I just want to the way how I can create the toolbar then how to load it and then how to excute the command on clicking the toolbar button using C#)
”Boost
