Robert,
One more thing. On the Revit disk there are some sample applications
which will definitely help you if you're just starting with the Revit
API. These samples and the API were improved with 8.1, so if you're
working with 8.0, I suggest you get the update.
Hope that helps,
-Danny
Danny P. wrote:
> Robert,
> I'm surprised that ADN sent you here. Autodesk only supports the Revit
> API through ADN, and you should get access to a developer to help you
> (if you're a member). I'm not an ADN member, so I'm not sure where to
> point you there, sorry.
> Outside of that you're left to only a few of us who are actually working
> with it. Some of the developers read the AUGI posts and sometimes
> reply, but they aren't obligated to do so. Your best bet for all Revit
> related discussions outside of ADN is at AUGI.
> -Danny
> Danny P. wrote:
>>Robert,
>>Unfortunately, there is no SelectOnScreen method in the Revit API.
>>You'll need to use the ActiveSelection in order to interact with the user.
>>Also, this .NET discussion group is for AutoCAD. I suggest you post
>>your Revit API questions on the ADN discussion groups or at AUGI's site:
>>http://forums.augi.com/forumdisplay.php?f=218
>>Hope that helps,
>>Danny Polkinhorn
>>WATG
>>Honolulu
>>robert vetrano wrote:
>>>Hi
>>>Have a form with a button. When button is pick want to hide form then select
>>>object on screen and return to form.
>>>Can't find any info on how to use SelectOnScreen. Am using Studio.net with
>>>Revit API.
>>>Appreciate if someone could point me in the right direction.
>>>Thanks
>>>bob v
