.NET
Active Contributor
jshipley
Message 1 of 8 (1,797 Views)
Another DWGThumbnail post
1797 Views, 7 Replies
04-29-2011 08:13 AM
Sorry - but I just can't get this thing to work (DWGThumbnail).  I have read everything I could find.
Here is my problem in a nutshell:  I am creating a Windows forms application that includes the AutoCAD DWG Thumbnail OCX control on the form.  I can't get this to work on a Windows 7 64bit machine.
On my develpment machine (which is Windows Vista 32 bit), I created a small Winform app, added the COM AutoCAD Thumbnail OCX reference (DWGTHUMBNAIL.OCX) version 2.0.
Then placed this control on my form.  Visual Studio then adds the references to the project: Interop.DWGTHUMBNAILLib.dll and AxInterop.DWGTHUMBNAILLib.dll.  I set them to 'Copy Local'.  So far so good.
I run the project in debug mode and it starts and runs fine (on the development machine).
I publish the app using ClickOnce (how I have deployed many apps).
Install the app on the Win7 64 bit machine and get: 'Exception from HRESULT: 0x80040154 REGDB_E_CLASSNOTREG...'
I have tried copying Both DLL's and registering them with Regsvr32, I have tried using Regasm, every which way!
Is this the correct version of the DWG Thumbnail control?
Why can't Autodesk make a .Net assembly of it???
Note - I am not a member of ADN, so I can't get any stuff there.
Help!!! :smileysad:
Imports System
Imports System.Drawing
Imports System.Drawing.Imaging
Imports System.IO
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Class acThumbnailReader
<StructLayout(LayoutKind.Sequential)> _
Private Structure BITMAPINFOHEADER
Public biSize As Integer
Public biWidth As Integer
Public biHeight As Integer
Public biPlanes As Short
Public biBitCount As Short
Public biCompression As Integer
Public biSizeImage As Integer
Public biXPelsPerMeter As Integer
Public biYPelsPerMeter As Integer
Public biClrUsed As Integer
Public biClrImportant As Integer
End Structure
Private Structure IMGREC
Public bytType As Byte
Public lngStart As Integer
Public lngLen As Integer
End Structure
Private Structure RGBQUAD
Public rgbBlue As Byte
Public rgbGreen As Byte
Public rgbRed As Byte
Public rgbReserved As Byte
End Structure
Public Shared Function GetThumbnail(strFile As String) As Bitmap
Return GetThumbnail(strFile, True, False, "")
End Function
Public Shared Function GetThumbnail(strFile As String, boolRetainBackColor As Boolean) As Bitmap
Return GetThumbnail(strFile, boolRetainBackColor, False, "")
End Function
Public Shared Function GetThumbnail(strFile As String, boolRetainBackColor As Boolean, boolSaveToFile As Boolean) As Bitmap
Return GetThumbnail(strFile, boolRetainBackColor, boolSaveToFile, "")
End Function
Public Shared Function GetThumbnail(strFile As String, boolRetainBackColor As Boolean, boolSaveToFile As Boolean, strSaveName As String) As Bitmap
Dim bmp As New Bitmap(1, 1, PixelFormat.Format8bppIndexed)
Dim bytCnt As Byte
Dim bytBMPBuff As Byte()
Dim lngImgLoc As Integer
Dim fs As FileStream = Nothing
Dim br As BinaryReader = Nothing
Dim lngCurLoc As Integer
Dim lngY As Integer
Dim lngX As Integer
Dim lngColor As Integer
Dim lngCnt As Integer
Dim intCnt As Short
Dim udtRec As IMGREC
Dim udtColors As RGBQUAD()
Dim udtColor As RGBQUAD
Dim udtHeader As BITMAPINFOHEADER
Dim intRed As Short
Dim intGreen As Short
Dim intBlue As Short
Try
If File.Exists(strFile) Then
fs = File.OpenRead(strFile)
br = New BinaryReader(fs)
fs.Seek(13, SeekOrigin.Begin)
lngImgLoc = br.ReadInt32()
fs.Seek(lngImgLoc + 17, SeekOrigin.Begin)
lngCurLoc = lngImgLoc + 17
fs.Seek(lngCurLoc + 3, SeekOrigin.Begin)
bytCnt = br.ReadByte()
If bytCnt > 1 Then
For intCnt = 0 To bytCnt - 1
udtRec.bytType = br.ReadByte()
udtRec.lngStart = br.ReadInt32()
udtRec.lngLen = br.ReadInt32()
If udtRec.bytType = 2 Then
fs.Seek(udtRec.lngStart, SeekOrigin.Begin)
udtHeader.biSize = br.ReadInt32()
udtHeader.biWidth = br.ReadInt32()
udtHeader.biHeight = br.ReadInt32()
udtHeader.biPlanes = br.ReadInt16()
udtHeader.biBitCount = br.ReadInt16()
udtHeader.biCompression = br.ReadInt32()
udtHeader.biSizeImage = br.ReadInt32()
udtHeader.biXPelsPerMeter = br.ReadInt32()
udtHeader.biYPelsPerMeter = br.ReadInt32()
udtHeader.biClrUsed = br.ReadInt32()
udtHeader.biClrImportant = br.ReadInt32()
bytBMPBuff = New Byte(udtRec.lngLen) {}
If udtHeader.biBitCount = 8 Then
udtColors = New RGBQUAD(255) {}
For count As Integer = 0 To 255
udtColors(count).rgbBlue = br.ReadByte()
udtColors(count).rgbGreen = br.ReadByte()
udtColors(count).rgbRed = br.ReadByte()
udtColors(count).rgbReserved = br.ReadByte()
Next
fs.Seek(udtRec.lngStart - 1, SeekOrigin.Begin)
For count As Integer = 0 To udtRec.lngLen
bytBMPBuff(count) = br.ReadByte()
Next
bmp = New Bitmap(udtHeader.biWidth, udtHeader.biHeight)
lngCnt = 0
For lngY = 1 To udtHeader.biHeight
For lngX = udtHeader.biWidth To 1 Step -1
lngColor = bytBMPBuff(bytBMPBuff.GetUpperBound(0) - lngCnt)
udtColor = udtColors(lngColor)
intRed = Convert.ToInt16(udtColor.rgbRed)
intGreen = Convert.ToInt16(udtColor.rgbGreen)
intBlue = Convert.ToInt16(udtColor.rgbBlue)
lngColor = ColorTranslator.ToOle(Color.FromArgb(intRed, intGreen, intBlue))
If boolRetainBackColor = False Then
If lngColor = ColorTranslator.ToOle(Color.Black) Then
lngColor = ColorTranslator.ToOle(Color.White)
Else
If lngColor = ColorTranslator.ToOle(Color.White) Then
End If
End If
End If
bmp.SetPixel(lngX - 1, lngY - 1, ColorTranslator.FromOle(lngColor))
lngCnt += 1
Next
Next
End If
GoTo Exit_Here
Else
If udtRec.bytType = 3 Then
GoTo Exit_Here
End If
End If
Next
End If
End If
Catch ex As Exception
MessageBox.Show(ex.Message.ToString())
GoTo Exit_Here
End Try
Exit_Here:
If br IsNot Nothing Then
br.Close()
fs.Close()
fs.Dispose()
End If
If boolSaveToFile = True Then
If strSaveName = "" Then
Dim fName As String
fName = [String].Concat(Path.GetTempPath(), Path.GetFileNameWithoutExtension(Path.GetRandomFileName()), ".bmp")
bmp.Save(fName)
Else
bmp.Save(strSaveName)
End If
End If
Return bmp
End Function
End Class
Active Contributor
jshipley
Message 2 of 8 (1,793 Views)
Re: Another DWGThumbnail post
04-29-2011 08:45 AM in reply to: jshipley
What about 3rd party options?  Are there any out there?  I'd be willing to pay for a reliable, stable .Net AutoCAD thumbnail control.  This seems harder than it should be...
Distinguished Contributor
Irvin
Message 3 of 8 (1,787 Views)
04-29-2011 10:01 AM in reply to: jshipley
Hi there please look at the attached class file.
This should help you. More info about this class can be found at the swamp.
http://www.theswamp.org/index.php#2
Kind regards,
Irvin
Active Contributor
jshipley
Message 4 of 8 (1,783 Views)
04-29-2011 10:08 AM in reply to: Irvin
Thanks - I have not registered at TheSwamp yet, but the class file looks good, do you possibly have it in VB?
Irvin
Message 5 of 8 (1,779 Views)
04-29-2011 10:15 AM in reply to: jshipley
Imports System
Imports System.IO
	End Structure
	End Structure
	End Structure
	End Function
	End Function
	End Function
		Dim bytCnt As Byte
		Dim lngY As Integer
		Dim lngX As Integer
		Dim intCnt As Short
		Dim intRed As Short
		Try
				If bytCnt > 1 Then
								Next
								Next
								lngCnt = 0
											Else
												End If
											End If
										End If
										lngCnt += 1
									Next
								Next
							End If
							GoTo Exit_Here
						Else
								GoTo Exit_Here
							End If
						End If
					Next
				End If
			End If
			GoTo Exit_Here
		End Try
		Exit_Here:
			br.Close()
			fs.Close()
			fs.Dispose()
		End If
				Dim fName As String
				bmp.Save(fName)
			Else
			End If
		End If
		Return bmp
	End Function
End Class
Active Contributor
jshipley
Message 6 of 8 (1,770 Views)
04-29-2011 10:33 AM in reply to: Irvin
THANK YOU!!!!  :smileyhappy:
That works great.  I removed the DwgThumbnail references and control, created the acThumbnailReader class, used it on my form, published it, and it works on the 64bit system.
Thanks again.
Jim
Irvin
Message 7 of 8 (1,750 Views)
04-29-2011 01:20 PM in reply to: jshipley
Glad to help you with your problem.
But thanks go out to the original programmers.
Kind regards,
Irvin
sanpo
Message 8 of 8 (804 Views)
01-07-2013 10:15 PM in reply to: jshipley
Can you explain how you used the class? (broad steps, if you can tell)
Does it work on 32 bit m/c too?
Regards
Shreenivas Potnis
