.NET
FRFR1586
Message 1 of 11 (366 Views)
annotative mleader problem
366 Views, 10 Replies
02-04-2014 09:50 AM
Hi everybody,
I have a problem about mtext textheight inside annotative mleader.
my software create a mleader object in the model space , this mleader use a mtext object
the mtext use the default textstyle
if , then creating the leader, the annotative scale of the model space is not 1:1 ,
the mtext textheight is autatcly divided by the annotative scale
(for example : original textheight=2.5, annotative scale=20 , after insertion the textheight is 0.125, exactly 2.5/20)
How can I create my mleader the the desired textheight ?
joined , you can find a sample of my project
regards
Luc
The mleader just uses the contents of the mtext or just just copies the contents.
To set the hieght use MLeader.TextHeight Property
Normally set it from its MleaderStyle.TextHeight
 Leader.TextHeight = 30
 instead of
mText.Height or TextHeight
 <CommandMethod("TST_L", CommandFlags.Modal)> _
Public Sub TST_L()
Dim Doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = Doc.Editor
Dim db As Database = ed.Document.Database
Dim Dl As Autodesk.AutoCAD.ApplicationServices.DocumentLock = Doc.LockDocument(Autodesk.AutoCAD.ApplicationServices.DocumentLockMode.ProtectedAutoWrite, "", "", False)
Using Dl
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim PtFleche As New Point3d(0, 0, 0)
Dim PtFleche2 As New Point3d(PtFleche.X + 4, PtFleche.Y + 4, PtFleche.Z)
Dim PtTexte As New Point3d(PtFleche.X + 8, PtFleche.Y + 6, PtFleche.Z)
Dim Leader As New MLeader
Leader.SetDatabaseDefaults()
Leader.ContentType = ContentType.MTextContent
'Leader.LayerId = CalqId
Leader.ArrowSize = 2.0
Leader.EnableDogleg = False
Dim idx As Integer = Leader.AddLeaderLine(PtFleche2)
Leader.AddFirstVertex(idx, PtFleche)
Leader.Annotative = AnnotativeStates.True
btr.AppendEntity(Leader)
tr.AddNewlyCreatedDBObject(Leader, True)
Using mText As New MText()
mText.Contents = "MyTexte"
Leader.MText = mText
End Using
'Dim mlstyle As MLeaderStyle = Leader.MLeaderStyle.GetObject(OpenMode.ForRead)
'Leader.TextHeight = mlstyle.TextHeight
tr.Commit()
End Using
MsgBox("now change the annotation scale to 20 (for exemple)" & vbCrLf & _
"then restart the tst_l command" & vbCrLf & vbCrLf & _
"then look at the text height of the new leader" & vbCrLf & _
"it is le 20th of the previous one")
End Sub
Distinguished Contributor
CommCorp
Message 2 of 11 (357 Views)
Re: annotative mleader problem
02-04-2014 10:51 AM in reply to: FRFR1586
I just went through adding mleaders myself and i think i can offer some suggestions.
Instead of "mText.Height = 30" try "mText.TextHeight = 30". I fell for that same trick and i think this will fix your problem.
Also, I had to attach the mtext to the mleader AFTER the mleader had been added to the modelspace, but this may have nothing to do with your issue.
JoAnn_Hogan
Message 3 of 11 (349 Views)
02-04-2014 11:37 AM in reply to: CommCorp
HI There,
The idea of using annotative text is for viewports. Now if your text height in Model Space is for example 3mm, and you have 4 viewports with different scales, your text height in paper space will remain 3mm even if you have different scales.
If this post solved your issue please mark as solved and Kudos are always welcome =)
Jo - Ann
Twitter: @JoAnn_Hogan
AutoCAD Certified Professional 2015 / Inventor Certified Professional 2015
FRFR1586
Message 4 of 11 (328 Views)
02-04-2014 11:46 PM in reply to: CommCorp
this don't solve the problem
the result is the same then adding then mtext.textheight=2.5 line
an other idea ?
regards
luc
CommCorp
Message 5 of 11 (313 Views)
02-05-2014 04:21 AM in reply to: FRFR1586
Is the code you attached working?
I ask because I see that you did not AppendEntity or AddNewlyCreatedDBObject your mtext object.
I tried that in my code and it would not run.
I attached what I did, hopefully it will help.
FRFR1586
Message 6 of 11 (299 Views)
02-05-2014 11:57 PM in reply to: CommCorp
hi,
my code is working (expect the text height problem)
I'm working with the 2014 autocad version
while testing your code , I have then same size problem
Have you tested your solution in my sample case ?
regards
Luc
CommCorp
Message 7 of 11 (291 Views)
02-06-2014 03:35 AM in reply to: FRFR1586
The only other thing I can think of is your "Annotation Plot Size" setting, is that correct?
After that, I'm out of ideas.
FRFR1586
Message 8 of 11 (259 Views)
02-11-2014 04:49 AM in reply to: CommCorp
hi,
I don't know how to verify Annotation Plot Size in vanilla autocad
luc
CommCorp
Message 9 of 11 (243 Views)
02-11-2014 07:45 AM in reply to: FRFR1586
On command line type “units”
A dialog box should open, go to the “Scale” tab and “Annotation Plot Size:” is at the top right.
Ours is set to 3/32”
Valued Mentor
jeff
Message 10 of 11 (237 Views)
02-11-2014 08:08 AM in reply to: CommCorp
 instead of
        Public Sub TST_L()
            Using Dl
                End Using
                tr.Commit()
            End Using
        End Sub
You can also find your answers @ TheSwamp
