.NET
Annotation scale
5 REPLIES 5
Ertqwa
567 Views, 5 Replies
Annotation scale
If I have an annotative object, with multiple annotative scales, but not the current one, AutoCAD will display it picking one of its annotative scales.
How do I find out which annotative scale AutoCAD is using to display an annotative object that has not the current annotation scale?
Thank you.
5 REPLIES 5
augusto.goncalves
in reply to: Ertqwa
Ertqwa
in reply to: augusto.goncalves
That post doesn't answer my question, it shows how to get the current  annotation scale in modelspace.
Thank you for the reply.
Balaji_Ram
in reply to: Ertqwa
There is no direct API to get the annotation scale that the entity is using.
As a workaround, you can try digging a little deep into the extension dictionary and getting it by looking for a DXF code 300. Using ArxDbg snoop tool, you can locate it.
I have shared a C++ code that does this which might be of some help to investigate this further.
I am having issues in uploading the zip file to this forum post. So I have shared it using dropbox :
https://www.dropbox.com/s/p8kjcm4l19r7iux/SampleCode.zip
Balaji
Developer Technical Services
Autodesk Developer Network
Ertqwa
in reply to: Balaji_Ram
Oh that is too bad. But good to know.
I'll look into your suggestion. The link did not work for me.
Balaji_Ram
in reply to: Ertqwa
Sorry, I might have removed it while clearing files from my dropbox folder.
Here is the link :
https://www.dropbox.com/s/8eodlfejmdzukvq/EntityAnnoScale.zip
Balaji
”Boost
