.NET
BrentBurgess1980
Message 1 of 4 (287 Views)
Annotation Scale Sorting
287 Views, 3 Replies
12-20-2011 05:42 PM
I have the following code to add annocation scales.
        public static void AddScale(string Name, double PaperUnits, double DrawingUnits)
            try
                ObjectContextManager ocm = HostApplicationServices.WorkingDatabase.ObjectContextManager;
                if (ocm != null)
                    ObjectContextCollection occ =
                        ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
                    if (occ != null)
                        if (!(occ.HasContext(Name)))
                            // new scale
                            AnnotationScale annotationScale = new AnnotationScale();
                            annotationScale.Name = Name;
                            annotationScale.PaperUnits = PaperUnits;
                            annotationScale.DrawingUnits = DrawingUnits;
                            Editor ed = AcApp.DocumentManager.MdiActiveDocument.Editor;
                            //ed.WriteMessage(string.Format("\n{0}", annotationScale.Name));
                            //add to context collection
                            occ.AddContext(annotationScale);
            catch (System.Exception ex)
                AcApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString());
        public static void ClearScaleList()
            Database db = HostApplicationServices.WorkingDatabase;
            try
                ObjectContextManager ocm = db.ObjectContextManager;
                if (ocm != null)
                    ObjectContextCollection occ = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
                    if (occ != null)
                        foreach (AnnotationScale anScale in occ)
                            if (!(occ.CurrentContext.Name.Equals(anScale.Name)))
                                //ed.WriteMessage("\n" + anScale.Name + " : removed");
                                occ.RemoveContext(anScale.Name);
                ed.WriteMessage(ex.ToString());
 When I run the folllowing code
            Setup.ScaleList.ClearScaleList();
            Setup.ScaleList.AddScale("1:1", 1,1);
            Setup.ScaleList.AddScale("1:2", 1, 1);
            Setup.ScaleList.AddScale("1:4", 1, 1);
            Setup.ScaleList.AddScale("1:8", 1, 1);
            Setup.ScaleList.AddScale("1:10", 1, 1);
            Setup.ScaleList.AddScale("1:16", 1, 1);
            Setup.ScaleList.AddScale("1:20", 1, 1);
            Setup.ScaleList.AddScale("1:30", 1, 1);
            Setup.ScaleList.AddScale("1:40", 1, 1);
            Setup.ScaleList.AddScale("1:50", 1, 1);
            Setup.ScaleList.AddScale("1:100", 1, 1);
            Setup.ScaleList.AddScale("1:200", 1, 1);
            Setup.ScaleList.AddScale("1:250", 1, 1);
            Setup.ScaleList.AddScale("1:500", 1, 1);
            Setup.ScaleList.AddScale("1:1000", 1, 1);
            Setup.ScaleList.AddScale("1:2000", 1, 1);
            Setup.ScaleList.AddScale("1:5000", 1, 1);
            Setup.ScaleList.AddScale("1:10000", 1, 1);
            Setup.ScaleList.AddScale("1:20000", 1, 1);
            Setup.ScaleList.AddScale("1:50000", 1, 1);
            Setup.ScaleList.AddScale("1:100000", 1, 1);
            Setup.ScaleList.AddScale("1:200000", 1, 1);
            Setup.ScaleList.AddScale("1:250000", 1, 1);
            Setup.ScaleList.AddScale("1:500000", 1, 1);
 it adds all of the scales, but they are displayed in this order
1:2
1:100
1:200
1:250
1:500
1:1000
1:2000
1:5000
1:10000
1:20000
1:50000
1:4
1:100000
1:200000
1:250000
1:500000
1:8
1:10
1:16
1:20
1:30
1:40
1:50
1:1
Is there a way to sort Annotation scales?
Hallex
Message 2 of 4 (271 Views)
Re: Annotation Scale Sorting
12-21-2011 04:18 AM in reply to: BrentBurgess1980
I'm afraid you're out off luck
because of AutoCAD has its own sorting rule...
BrentBurgess1980
Message 3 of 4 (256 Views)
12-21-2011 04:14 PM in reply to: Hallex
Halex - I managed to find a solution to this, although it did take a lot of time trawling through the AcScaleList.dll in ILSpy to find that the Autodesk.AutoCAD.Internal as a ScaleListHelpers Class and used that to develop this, and it is sorted the way I was hoping.
using System.Collections.Generic;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Internal;
using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace Setup
    public class ScaleLists
        #region "Members"
        private static List<string> ScaleListName = new List<string>();
        private static List<double> ScaleListNumerators = new List<double>();
        private static List<double> ScaleListDenominator = new List<double>();
        #endregion
        #region "Public Methods"
        public static void AddScaleLists()
            ScaleListName.Clear();
            ScaleListNumerators.Clear();
            ScaleListDenominator.Clear();
            //only runs if the GetScales returns a false value
            ScaleListName = GetScaleListString();
            ScaleListNumerators = GetScaleNumerator();
            ScaleListDenominator = GetScaleDenominator();
            ScaleListHelpers.updateScaleList(ScaleListName, ScaleListName, ScaleListNumerators, ScaleListDenominator, ScaleListDenominator.Count);
        #endregion
        #region "Private Methods"
        private static List<string> GetScaleListString()
            List<string> Temp = new List<string>();
            Temp.Add("1:1");
            Temp.Add("1:2");
            Temp.Add("1:4");
            Temp.Add("1:8");
            Temp.Add("1:10");
            Temp.Add("1:16");
            Temp.Add("1:20");
            Temp.Add("1:30");
            Temp.Add("1:40");
            Temp.Add("1:50");
            Temp.Add("1:100");
            Temp.Add("1:200");
            Temp.Add("1:250");
            Temp.Add("1:500");
            Temp.Add("1:1000");
            Temp.Add("1:2000");
            Temp.Add("1:5000");
            Temp.Add("1:10000");
            Temp.Add("1:20000");
            Temp.Add("1:50000");
            Temp.Add("1:100000");
            Temp.Add("1:200000");
            Temp.Add("1:250000");
            Temp.Add("1:500000");
            return Temp;
        private static List<double> GetScaleNumerator()
            List<double> Temp = new List<double>();
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            Temp.Add(1);
            return Temp;
        private static List<double> GetScaleDenominator()
            Temp.Add(1);
            Temp.Add(2);
            Temp.Add(4);
            Temp.Add(8);
            Temp.Add(10);
            Temp.Add(16);
            Temp.Add(20);
            Temp.Add(30);
            Temp.Add(40);
            Temp.Add(50);
            Temp.Add(100);
            Temp.Add(200);
            Temp.Add(250);
            Temp.Add(500);
            Temp.Add(1000);
            Temp.Add(2000);
            Temp.Add(5000);
            Temp.Add(10000);
            Temp.Add(20000);
            Temp.Add(50000);
            Temp.Add(100000);
            Temp.Add(200000);
            Temp.Add(250000);
            Temp.Add(500000);
            return Temp;
        #endregion
 So far it seems to be working ok... fingers crossed!
Hallex
Message 4 of 4 (241 Views)
12-22-2011 03:32 AM in reply to: BrentBurgess1980
Holy Cow!
Ya da man
Accepted for 2010 :smileyhappy:
Oleg
