.NET
Alternative method for SetFocusToDwgView()?
1 REPLY 1
433 Views, 1 Reply
Unfortunately, ARX 2007 does not provide Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView().
What would be the best way to mimic this method?
1 REPLY 1
Alexander.Rivilis
Try this code (not the same as SetFocusToDwgView but can be helpful):
[DllImport("user32.dll")]
extern static IntPtr SetFocus(IntPtr hWnd);
static void SetFocusToActiveDocument()
  SetFocus(Application.DocumentManager.MdiActiveDocument.Window.Handle);
static void SetFocusToMainWindow()
  SetFocus(Application.MainWindow.Handle);
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
