Unfortunately, ARX 2007 does not provide Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView().
What would be the best way to mimic this method?
Try this code (not the same as SetFocusToDwgView but can be helpful):
[DllImport("user32.dll")] extern static IntPtr SetFocus(IntPtr hWnd); static void SetFocusToActiveDocument() { SetFocus(Application.DocumentManager.MdiActiveDocument.Window.Handle); } static void SetFocusToMainWindow() { SetFocus(Application.MainWindow.Handle); }
Facebook | Twitter | LinkedIn
