.NET
Aligning Object by points
6 REPLIES 6
1306 Views, 6 Replies
Hi All,
Is it possible to align object by 2/3 point using .net?
Its easy to do with autocad, but I can't find a way to do it using .NET
Thanks in advance
6 REPLIES 6
DiningPhilosopher
You can use Matrix3d.AlignCoordinateSystem() and Entity.TransformBy() to do thiat.  Search the discussion groups and  any other resources you have access to for 'Matrix3d.AlignCoordinateSystem', and you should find some code that will help show how its done.
in reply to: DiningPhilosopher
Hi DiningPhilosopher,
I follow your suggestion. But get an error when doing the transformation
Error Code: Autodesk.AutoCAD.Runtime.Exception : {"eCannotScaleNonUniformly"}
Did I miss something?
Here is my code :
<CommandMethod("tal")> _
Public Sub TestAlignment()
   Dim doc As Document = AcApp.DocumentManager.MdiActiveDocument
   Dim db As Database = HostApplicationServices.WorkingDatabase
   Dim ed As Editor = doc.Editor
   Using tr As Transaction = db.TransactionManager.StartTransaction
      Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
      Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
     Dim ppr As PromptPointResult = ed.GetPoint(vbLf & "Select 1 Origin")
     Dim pt1 As Point3d = ppr.Value
     ppr = ed.GetPoint(vbLf & "Select 2 Origin")
     Dim pt2 As Point3d = ppr.Value
     ppr = ed.GetPoint(vbLf & "Select 1 dest")
     Dim pt3 As Point3d = ppr.Value
     ppr = ed.GetPoint(vbLf & "Select 2 dest")
     Dim pt4 As Point3d = ppr.Value
     Dim l1 As Line = New Line(pt1, pt2)
     Dim dist As Double = l1.Length
     Dim vc As Vector3d = pt1.GetVectorTo(pt2)
     vc = vc.GetNormal
     Dim cs0 As CoordinateSystem3d = New CoordinateSystem3d(pt1, vc, vc.CrossProduct(l1.Normal).Negate)
     Dim l2 As Line = New Line(pt3, pt4)
     Dim vc1 As Vector3d = pt3.GetVectorTo(pt4)
     vc1 = vc1.GetNormal
     pt4 = l2.GetPointAtDist(dist)
     l2.EndPoint = pt4
     Dim cs1 As CoordinateSystem3d = New CoordinateSystem3d(pt3, vc1, vc.CrossProduct(l2.Normal).Negate)
     Dim mtx As Matrix3d = Matrix3d.AlignCoordinateSystem(pt1, cs0.Xaxis, cs0.Yaxis, cs0.Zaxis, pt3, _
                                         cs1.Xaxis, cs1.Yaxis, cs1.Zaxis)
     Dim per As PromptEntityResult = ed.GetEntity(vbLf & "Select Object to align")
     Dim ent As Entity = tr.GetObject(per.ObjectId, OpenMode.ForWrite)
     ent.TransformBy(mtx) --> Error Here : Autodesk.AutoCAD.Runtime.Exception : {"eCannotScaleNonUniformly"}
      tr.Commit()
   End Using
End Sub
Alexander.Rivilis
Example: http://adndevblog.typepad.com/autocad/2012/04/finding-transformation-matrix-for-aligning-two-entitie...
Facebook | Twitter | LinkedIn
Expert Elite Member
Hallex
Try to do it without changing UCS, here is a quick scratch
expand them to your suit:
        <CommandMethod("Agn")> _
        Public Shared Sub TestAlignObject()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Try
                    ' Prompt for the object to align
                    Dim pso As New PromptSelectionOptions()
                    pso.MessageForRemoval = vbLf & "Invalid Selection."
                    pso.MessageForAdding = vbLf & "Select object:"
                    Dim per As PromptSelectionResult = ed.GetSelection(pso)
                    If per.Status <> PromptStatus.OK Then
                        Return
                    End If
                    Dim sset As SelectionSet = per.Value
                    Dim id As ObjectId = sset.GetObjectIds()(0)
                    Dim obj As Entity = TryCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
                    Dim ps1 As Point3d = ed.GetPoint(vbLf & "First source point: ").Value
                    Dim pt1 As Point3d = ed.GetPoint(vbLf & "First destination point: ").Value
                    Dim ps2 As Point3d = ed.GetPoint(vbLf & "Second source point: ").Value
                    Dim pt2 As Point3d = ed.GetPoint(vbLf & "Second destination point: ").Value
                    Dim plan As Plane = obj.GetPlane()
                    Dim ang1 As Double = (pt1 - pt2).AngleOnPlane(plan)
                    Dim ang2 As Double = (ps1 - ps2).AngleOnPlane(plan)
                    Dim ang As Double = ang1 - ang2
                    Dim mtx As Matrix3d = Matrix3d.Rotation(ang, Vector3d.ZAxis, ps1)
                    obj.TransformBy(mtx)
                    mtx = Matrix3d.Displacement(pt1 - ps1)
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
                    Return
                End Try
            End Using
        End Sub
in reply to: Alexander.Rivilis
Hi Alexander,
I have try your code. But it align perpendicularly, and also it will align entity size (when possible).
I'm trying to do it by making a mirror line in the middle of 1st origin and destination and 2nd origin and destination point.
The problem is if origins and destinations already in parallel, the code can't align to the opposite.
Here is my code:
                Dim per As PromptEntityResult = ed.GetEntity(vbLf & "Select block to align")
                Dim br As BlockReference = tr.GetObject(per.ObjectId, OpenMode.ForWrite)
                'select point origin
                'This will be origin point
                Dim ptO As Point3d = pt1
                'select point destination
                'This will be destination point
                Dim ptD As Point3d = pt4
                'Create temporary line for origin and destination points
                'Make sure distance between origin and destination points are same
                If l2.Length > l1.Length Then
                    pt4 = l2.GetPointAtDist(l1.Length)
                    l2.EndPoint = pt4
                ElseIf l2.Length < l1.Length Then
                    pt2 = l1.GetPointAtDist(l2.Length)
                    l1.EndPoint = pt2
                End If
                'Find middle point of 1st & 2nd origin and destination
                Dim m1 As Point3d = New Point3d((pt1.X + pt3.X) * 0.5, (pt1.Y + pt3.Y) * 0.5, (pt1.Z + pt3.Z) * 0.5)
                Dim m2 As Point3d = New Point3d((pt2.X + pt4.X) * 0.5, (pt2.Y + pt4.Y) * 0.5, (pt2.Z + pt4.Z) * 0.5)
                'Create temporary line for mirroring purpose
                Dim l5 As Line3d = New Line3d(m1, m2)
                br.TransformBy(Matrix3d.Mirroring(l5))
                br.TransformBy(Matrix3d.Displacement(br.Position.GetVectorTo(ptD)))
                'br.Rotation = br.Rotation * -1
                tr.Commit()
            End Using
        End Sub
regards
Abufaisal
in reply to: Hallex
            Using tr
                Try
                        Return
                    End If
                    tr.Commit()
                    Return
                End Try
            End Using
        End Sub
Hi Hallex,
I tried your code, but it only worked in 2D. I need it to work in 3D space. I think it's because you use zAxis as vector, but I don't know either how to determine the vector. I have tried to make some code, but still not perfect, maybe you have some idea how to perfect it.
I already upload my code in my reply to Alexander
Regards
Abufaisal
”Boost
